Re: Challenger dutchman to 1/4 seam sealer
[Re: Mopar.70]
#791348
09/05/10 01:10 AM
09/05/10 01:10 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
What product are you guys using to duplicate this. I have to do the seams on my Satellite, I cleaned them out with a wire wheel and primed them now I need to seal it for the correct look
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: gregsrt]
#791349
09/05/10 02:25 PM
09/05/10 02:25 PM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
I just did mine yesterday. First put 3M green tape right up to the edge with a 1/16th edge away from it. Make sure its primered prior to putting it on. Run a solid bead the whole length. Then just use your finger to smear it in. You may end up needing to repeat the process after it dries.
Wait 24 hours or more before pulling the tape off. Once it is fully cured; sand off the overlapped edge and clean with laquer thinner.
3M Ultrapro Tan Heavy Bodied Seam Sealer 08301
I bought mine on E Bay.
