318 motor mounts... I need help! #791333
09/03/10 12:04 AM
09/03/10 12:04 AM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Okay, I've always read that a motor mount is a motor mount when 318's are concerned, well tonight I found that's not true. I can't believe I didn't notice this till it was time to drop in the engine.
There is a bolt "eye" missing in the new '76 block if I'm to use my '67 mounts.
5/23/67 block - old
5/27/76 block - new
mount brackets that were holding the 5/23/67 block in my '67 Belvedere
Do I need find the brackets from a mid 70's car? I think this block originally came from a truck.
Can someone please tell me what I need to look for? What vehicle and year? I guess... or am I missing something here...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: 318 motor mounts... I need help! [Re: closer9] #791334
09/03/10 12:37 AM
09/03/10 12:37 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like the original setup only used three bolts as well...
Re: 318 motor mounts... I need help! [Re: 1_WILD_RT] #791335
09/03/10 12:42 AM
09/03/10 12:42 AM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Yes, but on that side it used both holes. You can tell from the missing paint on that side on the 67 block.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: 318 motor mounts... I need help! [Re: closer9] #791336
09/03/10 12:46 AM
09/03/10 12:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Look at the mount bracket.. Only three holes... & even if there were a extra hole the passenger side of the engine is much lower stress than the drivers side so why have an extra bolt?
BTW the engine mount brackets are shown up side down...
Re: 318 motor mounts... I need help! [Re: closer9] #791337
09/03/10 06:48 PM
09/03/10 06:48 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Problem solved!
Once I realized which bracket goes on which side, I just put the bracket back in the old block with all three bolts, marked the 4th hole on the bracket, and drilled a new hole. There was plenty of material.
And it's all back in the car... and I have to go out of town for three days.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: 318 motor mounts... I need help! [Re: closer9] #791338
09/03/10 06:58 PM
09/03/10 06:58 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
So you drilled an extra hole that you don't need and didn't use it anyway...It that what I am seeing/reading?
Re: 318 motor mounts... I need help! [Re: QuickBpBp] #791339
09/03/10 11:39 PM
09/03/10 11:39 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Um, no. The bracket only had a hole on the lower left, the block only had a hole on the lower right. So, I drilled a hole in the bracket on the lower right.
Daily:
'19 Frontier 4WD
Belle:
Other:
