Page 1 of 3 1 2 3
70 B Body Education : Dash PLEASE #790085
09/01/10 03:34 PM
09/01/10 03:34 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
OK...
1970 Plymouth B Body with factory AIR GRABBER...
Is this the correct dash location?
Is the metal frame different, because there is not much room behind this switch hole location.
CHECK OUT MY NEW WEB SITE !
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790086
09/01/10 03:35 PM
09/01/10 03:35 PM
anlauto Offline OP
anlauto  Offline OP
Backside...
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790087
09/01/10 03:36 PM
09/01/10 03:36 PM
anlauto Offline OP
anlauto  Offline OP
This is all that I have for the switch...
What else am I missing?
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790088
09/01/10 03:37 PM
09/01/10 03:37 PM
anlauto Offline OP
anlauto  Offline OP
PG Classics lists a "air grabber solenoid" in their catalog...Do I need that as well? Where does it mount?
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790089
09/01/10 03:41 PM
09/01/10 03:41 PM
USA
b54406barrel Offline
USA
Looks about right. I haven't been behind my dash for 25 years though & have never touched the switch so not certain on the dash metal. Seems like there was a hole, though.
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790090
09/01/10 03:42 PM
09/01/10 03:42 PM
USA
USA
On top of the glove box, I think. Again, been so long...........
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790091
09/01/10 03:45 PM
09/01/10 03:45 PM
anlauto Offline OP
anlauto  Offline OP
OK, so my location looks right...I wonder if that "white block" of the switch screws directly to the metal frame?
Also (unrelated) If you don't want a map light, located just to the right of the heater controls, is there some sort of "block off plate" or something? Where could I get one of those?
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790092
09/01/10 03:56 PM
09/01/10 03:56 PM
USA
USA
My switch is really solid so it must be screwed to frame.
I don't have a light so yes, there is a block off plate. Bad picture though. Never looked for a repop one.
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790093
09/01/10 04:03 PM
09/01/10 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A correctly placed want ad , it's a metal plate , at least in 68 and 69 it's metal.
Re: 70 B Body Education : Dash PLEASE [Re: b54406barrel] #790094
09/01/10 04:15 PM
09/01/10 04:15 PM
anlauto Offline OP
anlauto  Offline OP
Rex
Is your glove box blue inside or black? I'm referring to the backside of the actual door?
John, thanks for that "want ad" tip
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790095
09/01/10 04:42 PM
09/01/10 04:42 PM
USA
USA
I don't have a picture but, it's black. Not sure if it's paint or just unfinished plastic.
Also, the 'box' on top of my glovebox might have been part of the 8T player, now that I think back. I pulled radio out to replace belt, many years back.
The solenoid is keyed so when you shut the car off, it immediately starts the closing process, makes a hissing noise from bleed off when ag switch is in on position & car shut off.
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790096
09/01/10 06:38 PM
09/01/10 06:38 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Alan,
Backside of the door should be black. I have a spare maplight if you want it, but I used my only blank off plate....sorry.
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790097
09/01/10 06:57 PM
09/01/10 06:57 PM
California
70SportSatellite Offline
super street
super street
California
Alan,
I may be mistaken but I thought the oval hole was for the reverse and air grabber switches? If this dash panel came out of a non grabber car they may have drilled the reverse hole offset.
Also, I believe the white block with the nipples is attached to the panel with the bezel screws.In other words, the plastic panel is sandwiched between the bezel and white block.
The solenoid was used to dump the air from the actuator when the car was shut off and the spring from the actuator bracket to the flap linkage would pull the door closed.
If you leave the solenoid out and leave the spring off the door will stay open when the car is shut off.
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790098
09/01/10 09:28 PM
09/01/10 09:28 PM
anlauto Offline OP
anlauto  Offline OP
I was told that the plastic bezel was an original, but I guess it's possible the steel frame has been changed
It would seem to me that the switch should be anchored to the steel frame for strength ?
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790099
09/01/10 10:28 PM
09/01/10 10:28 PM
USA
USA
I'm pretty sure the switch is attached to the metal, actually kind of under the dash plastic. I'll be driving the 6bbl car to the airport tomorrow. I can crawl under there & take a look & let you know what I find when I get back tomorrow night.
Re: 70 B Body Education : Dash PLEASE [Re: b54406barrel] #790100
09/01/10 10:47 PM
09/01/10 10:47 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I have the dash out of my 70 RR airgrabber car now. took a photo. Does it help?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 B Body Education : Dash PLEASE [Re: b54406barrel] #790101
09/01/10 10:48 PM
09/01/10 10:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The lamp blockoff plate is common to 1968-70 B-body, At least I think it is. ( maybe even 66-67 to )
I'm no help on the switch part though
Re: 70 B Body Education : Dash PLEASE [Re: JMCFAN] #790102
09/01/10 10:54 PM
09/01/10 10:54 PM
anlauto Offline OP
anlauto  Offline OP
the plot thickens....I don't believe I have that round hole next to the large oval
But I still don't quite understand how it all mounts together. It appears as if you don't have any additional screw holes
Re: 70 B Body Education : Dash PLEASE [Re: anlauto] #790103
09/01/10 10:57 PM
09/01/10 10:57 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
there are some there.. bad photo. Wil take a couple more
Re: 70 B Body Education : Dash PLEASE [Re: JMCFAN] #790104
09/01/10 11:04 PM
09/01/10 11:04 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
How is this I removed the airgrabber switch you have in our photo when I started striping it down. I tink I have photos of that as well.
Page 1 of 3 1 2 3
