What's a good idle speed for a 440?
#788894
08/30/10 11:44 PM
08/30/10 11:44 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
This might seem like an easy one, but I'm curious what an acceptable idle speed is for my 440. Right now, it sits at around 600RPM and seems happy. Vacuum is a little low (15"), but the truck charges and idles nicely. Is there a certain point that you settle at? Do you try and get it low enough relative to vacuum, charging amperage, and cooling ability of a mechanical water pump? Thanks for the help.
Re: What's a good idle speed for a 440?
[Re: az426john]
#788897
08/31/10 12:34 AM
08/31/10 12:34 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
Thanks for the input guys. Glad to hear I'm not too far off on this one. Oil pressure is nice and high at that speed, charging is sufficient. The only thing I might concern myself is cooling at this point, but that could easily be attributed to a number of other factors (that I'm aware of and working to repair). John, I'm still working on that timing issue. Just got the bugs worked out to where she's running pretty nicely. Hope all goes well on your business trip, and I look forward to getting in touch with you when you return
[Re: Pat_Whalen]
#788898
08/31/10 01:49 AM
08/31/10 01:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
wherever the tune/combo let's the idle speed fall!
for automatics with tighter torque converters, maybe bump it up a few hundred RPM to keep it from stalling when in drive at a stop light, but otherwise, let it idle where it wants!
mine idles around 750 with 25 psi oil pressure when it's hot.
**Photobucket sucks**
[Re: 70Cuda383]
#788899
08/31/10 07:57 AM
08/31/10 07:57 AM
Posts: 15,487 Florida
scratchnfotraction
mines around the 500-750 mark rev it up and it comes back down fast and smooth to the idle sits and purrrrs mine also will warm up around the 200* mark if i let it idle for 45-60 mins sitting there with the tranz in drive and pumping fluid I put a big fan in front last time and it stayed on the 180-190 mark on the t-stat for over an hour i am looking to fin a 7 blade clutch fan for it though,the 5 blade looks compaired to the 7 blade on the SB truck i would call it good
