SB waterpump, 6 blade impeller vs. 8 blade? #78881
06/23/08 08:23 PM
06/23/08 08:23 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
If I understand correctly, A/C impeller is 8 blade, but 6 blade unit is recommended for non-A/c and HP applications? I read on here that the water pump pulleys are different sizes and that they are spun at different speeds. Is this true?
I have been taking steps to cool down my hot running 360. I've got it running cool now when moving, but the temp still jumps quickly at a red light. Nearly to "H" on the stock guage on a long light. Engine then won't idle when its that hot, she's not happy sitting still. Presently running 9:1 comp, stock 318 2 row 22" rad with shroud and 5 blade viscous fan. Iron heads. 9.5" stall converter with deep pan and 2 medium sized trans coolers in series in front of the radiator. (68 B'cuda, non-a/c)
My next thoughts are (in order) 1) high flow thermostat, 2)high flow waterpump with disc on the impeller. 3) aftermarket radiator.
EDIT: I just got done reading the MP A engine book. It says use 6 blade pumps for drag racing and/or iron head and 8 blade pumps for aluminum heads and/or oval track racing if enging cooling is marginal or overheating. No mention of street use, but it sounds like an 8 blade is in order? Not that I have a lot of faith in what MP says...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: GO_Fish] #78882
06/23/08 08:39 PM
06/23/08 08:39 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Two much stuff in front of a radiator that might be too small is my first thought.
I know that when I put a trans cooler in front of my 67 mustang radiator the temps went up and when I took the the ac condenser out of my truck it ran cooler than before. Maybe moving the coolers off to the side or making sure they are spaced off the radiator at least. The fins on those are usually pretty tight together making it harder for the fan to pull air through the radiator especially if the fan is far away from the radiator.
All the smallblock upper pulleys that I have ever paid attention to have been the same size. Maybe they change speeds with the bottom pulley instead?
If you do go with another pump try the edelbrock or at least another one with the disk on the back. I have an edelbrock pump and milodon thermostat on my daily driver and like it a lot. It warms up fast and stays there. I have just the factory dummy guage, but I have stuck a cooking thermometer on the cylinder head and radiator on 90+ degree days and it gets to about 195 or 200 at most sitting still.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: GO_Fish] #78883
06/23/08 09:00 PM
06/23/08 09:00 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I use an 8 blade pump with my 340
I don't use underdrive performance crank pulley from March. At first I did but was overheating, replaced it with a larger pulley and am cooling fine. The underdrive pulley will slow down the water pump to gain a couple of horsepower
also Flow Kooler has a pump with 16 blades
http://www.flowkooler.com/pump.php?pid=WP1700&pid0=TS370
never tried one, just a heads up
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: Neil] #78884
06/23/08 09:05 PM
06/23/08 09:05 PM
Tennessee
HOOVER24K Offline
super street
HOOVER24K  Offline
super street
Tennessee
I had the same problem. The only differance was I had underdrive pulleys. I switched to a Flow-Cooler brand waterpump with 8 blades and the disc to increase flow and it did nothing to solve my overheating problem. I then switched to an electric fan and up graded the electric system to handle the extra amps needed at idle and Bingo. So it may be an air flow problem instead of a water flow problem.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: HOOVER24K] #78885
06/23/08 09:24 PM
06/23/08 09:24 PM
Andrewh Offline
Andrewh  Offline
actually it is the other way around. 8 blade for non-ac. 6 blade for a/c cars.
the a/c pulley is smaller so it spins faster.
But the offset is different I think so it doesn't line up with the non-a/c stuff.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: Andrewh] #78886
06/24/08 06:51 AM
06/24/08 06:51 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That is correct. The 6 blade is for the AC cars because they spin the fan faster to get more air through the radiator so less blades are used to try and prevent cavitation. The 8 blades are for the non AC cars which spin the fan slower. Both have the same shaft offset and can be interchanged. The older water pumps ('69 and earlier) are shorter then the later water pumps.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: 69Cuda340S] #78887
06/24/08 10:01 AM
06/24/08 10:01 AM
Andrewh Offline
Andrewh  Offline
sorry, I meant the offset on the pulley I think is different.
As I recall you have to have a matched set of pulley's and brackets for an a/c vs non-a/c set up for all the pulley's to line up.
Power steering and alt brackets, and the other pulley's.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: Andrewh] #78888
06/24/08 10:28 AM
06/24/08 10:28 AM
Most of the AC pulleys were on a big offset to the front and don't line up on car without AC.
Here is a pic of an AC pulley I modified to line up with stock non-AC pulleys. It was pretty easy to do, just took the outside of an AC pulley and the inside of the stock pulley and connected them with a piece of 3" exhaust tubing. (the alternater is repositioned too, to clear turbos but has std pulley on it)
Re: SB waterpump, 6 blade impeller vs. 8 blade? #78889
06/24/08 08:48 PM
06/24/08 08:48 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Well I just came back in from doing MP's cooling system "test". Not very scientific, but all it consists of is bringing the engine up to operating temperature with the radiator cap off and watching the coolant flow across the top of the radiator. There was very little flow with the engine at idle, you could see it pick up some, but not greatly when you gave it gas.
Then I did my own test for air flow. I took a 8.5"x17" piece of corrigated cardboard, and put it in front of the radiator and trans coolers with the engine idling. The fan sucked the cardboard up tight against the trans coolers and held it there, so I'm definitly getting adequate airflow at idle.
I just re-read Sanborn's Oval track cooling tips at Rapid Robert's suggestion ( ), and I think my next move is installing a 8 blade pump with a homemade Flowcooler disc (since they don't sell them any more ) and a high flow thermostat.
If you look at the stock impellers, they are just a piece of flat steel, cookie cuttered, then bent into shape. This makes a cheap but leaky impeller, prone to cavitation. They clearly were more so worried about keeping assembly costs down rather than creating a superior pump. The engineers and bean counters decided what was "good enough" and that's what we get in a stock pump.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: GO_Fish] #78890
06/24/08 11:55 PM
06/24/08 11:55 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
For '72 the AC cars use the 6 blade pump overdriven 1.3 to 1. Others use 8 blade driven at 0.95 to 1. Several different radiators and fans and clutches depending on options, best would be 18" fan 7 blades 2.25 wide, 22" radiator, shroud, thermal clutch. Low engine speed and low vehicle speed and overheating probabaly not moving enough coolant or enough air or both. Stock system in good condition is more than adequate. Sure MOPAR impeller is cheap; works; want a Mercedes? Buy a Mercedes...
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: GO_Fish] #78891
06/25/08 12:02 AM
06/25/08 12:02 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I bought a Mildon hight flow with a disk that is a nice unit.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: GO_Fish] #78892
06/25/08 02:12 AM
06/25/08 02:12 AM
Not to change the subject, but you can only do so much with a 22" radiator.
Glad my 74 360 4 speed Chally came with a 26" radiator.
Ma Mopar alway's thought a 22" radiator was fine for a 318 or 340 in the 70-73 years. NOT !!!!
I run a 3 core 26" radiator, 8 blade impeller water pump, thermostatic fan, iron heads, 4 speed, fan shroud not needed.
No fan shroud, and depending on what thermostat I put in (160 or 180), that is exactly what I measure all day long .....IN THE HOT TEXAS SUN, STOP AND GO.
Who needs a 26" fan shroud ?
Re: SB waterpump, 6 blade impeller vs. 8 blade? #78893
06/25/08 05:57 AM
06/25/08 05:57 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you have the '70 and up type water pump Edelbrock makes a high flow water pump. The after market ignores the earlier style water pumps as far as I know.
Re: SB waterpump, 6 blade impeller vs. 8 blade? [Re: 69Cuda340S] #78894
06/25/08 02:26 PM
06/25/08 02:26 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
IIRC, Mancini sells the early version high flow water pumps. They are cast iron though (as are most other early versions). I however have come across 2 aluminum early versions. 1 is on the 360 now and not getting the job done. The other is an aluminum '69 and earlier 8 blade that I got on EGAG last winter. This is the one I will make a disc for and run.
