anyone have pics of 68-70 era 7 blade fans? #788860
08/30/10 10:40 PM
08/30/10 10:40 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
I am trying to identify the one I bought off someone.
supposed to be RB/Hemi 7 blade fan from his old Bee .
got it for $20.00
I am going to put on my 68 Coronet and wanted to make sure its correct era.
I cant read the white painted numbers on it,
Re: anyone have pics of 68-70 era 7 blade fans? [Re: BobN] #788861
08/30/10 10:52 PM
08/30/10 10:52 PM
Arizona
az426john Offline
az426john  Offline
Arizona
If you posted a photo with some dimensions
OD
Blade width
Pitch
It might be easier for the folks to ID it.
Re: anyone have pics of 68-70 era 7 blade fans? [Re: BobN] #788862
08/30/10 10:54 PM
08/30/10 10:54 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
PART # 2843 225 STD for 383/440 w/o air,for C body cars.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: anyone have pics of 68-70 era 7 blade fans? [Re: 68Cbarge] #788863
08/30/10 11:07 PM
08/30/10 11:07 PM
BobN Offline OP
BobN  Offline OP
that looks like it. or darn close
has those 4 bolts holding each blade
I have to compare tomorrow in the daylight.
Do you think that should look ok on 440 on 68 coronet.
was hoping would cool better than my New Mopar 5 Blade clutch fan
what are your thoughts on that?
Re: anyone have pics of 68-70 era 7 blade fans? [Re: 68Cbarge] #788864
08/30/10 11:13 PM
08/30/10 11:13 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
here is what my parts catalouge lists for 7 blade fans;
note the car designation is the first letter of the VIN
7 blade STD fan 383 440 for R and W cars; 2863 202
7 blade for B and L cars w/383; 2863 213
7 blade for 440 w/manual trans,STD w/Hemi in R and W cars; 2863 215.
7 blade STD W/manual trans 440 in P and D cars (C body) 2863 216.
7 blade w/HI CAP FAN 383/440 ALL CARS EXCEPT V,B,and L cars 2843 188
I focused on the fans for the B/RB engines without A/C.
They are many more listed in my catalogue for other engines.
I can post more if needed.
Hope this helps
Re: anyone have pics of 68-70 era 7 blade fans? [Re: BobN] #788865
08/30/10 11:23 PM
08/30/10 11:23 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Should work OK provided you have the correct spacer for your application.
I got the numbers for them,too if needed.
One of the better fans I had used in the past was one from a mid-80's M body.
Cheap,cools great and still plentiful.
I recommend a shroud for best cooling performance.
I am sticking to the original fan for my resto project for now.
