Re: 383 head question.
[Re: JoesMopar]
#788789
08/31/10 11:38 PM
08/31/10 11:38 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Ok, I am severly confused then on what exactly a factory 383 build is then. They made HP 383's, what do they have from the factory that I can't dupilcate by being the cheap ass that I am without having to buy expensive pistons and machine work?
It's because of aftermarket piston choice. If you insist on doing it on the cheap use the KB400, it will get you above 9.0 compression and the the 268 will clear it fine.
[Re: JoesMopar]
#788792
09/01/10 09:41 AM
09/01/10 09:41 AM
JohnRR
Thanks so much. I hate to sound like a pain in the ass. I didn't know the new pistons were shorter than the factory ones. I know the lift on that cam is .494/.513. That amount of lift on a stock height block, with the pistons you recommended, using stock 906 heads should be ok without clipping a valve on the piston?
I was thinking that you were using a comp 268, that's more lift but as long as you don't zero deck the piston and or cut a ton off the heads you SHOULD be ok , but you'll want to check clearance anyway. Be forewarned the guides will need to be trimmed down so you don't have the retainers hitting them and of course use the voodoo speced springs.
If you haven't spent money on the heads yet you might try to scrape up a set of 516's, or even 915's since all of a sudden they have become worthless , and use a flat top piston.
