Re: Moving steering box over, any problems ???
[Re: ahy]
#788328
08/31/10 12:04 AM
08/31/10 12:04 AM
Posts: 8,885 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
To keep the steering wheel centered and the left vs right turning circle the same you will need to adjust the tie rods to compensate for the steering box offset.
To keep the wheel centered you remove the wheel and put it back on straight up (or close to it)!! There should only be a minor tie rod adjustment necessary to center the wheel.
[Re: ahy]
#788331
08/31/10 12:14 AM
08/31/10 12:14 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
My wheel ('70E) has a master spline so it only goes on one way... no adjustment possible. Perhaps others are different?
Nope.. Most anything newer than the mid fifties has a master spline.. Then the is the fact that the steering gear has one small area where the clearance between the gear teeth is a tighter fit.. That is the center position.. move away from that spot & there is more lash because in a turn the feedback pressure from the wheels will keep the gears tight... Going straight the gear needs to control the wheels more closely..
Then I gotta wonder what you plan to do about the frame rail & the steering box trying to occupy the same space...
[Re: Red383]
#788332
08/31/10 12:31 AM
08/31/10 12:31 AM
RapidRobert
If it's just the box that needs to be moved a ujoint steering shaft might be a plan. I hear borgeson (sp) is excellent quality and has a good selection. That'd keep the column alignment straight. I think you could lengthen 1 tie rod sleeve and shorten the other to keep the box at the center point w the wheels straight ahead. It'll take some fabbing
[Re: Stanton]
#788333
08/31/10 12:59 AM
08/31/10 12:59 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
BAD IDEA even if possible. With the wheels straight the steering gear needs to be in the center of its travel. This is accomplished by adjusting the tie rods (lengthen one while shortening the other the same amount)
[Re: 1_WILD_RT]
#788334
08/31/10 09:03 AM
08/31/10 09:03 AM
Posts: 1,629 OH
Red383
OH
There is at least a 1" gap between the steering box mount and frame rail. So they shouldn't take up the same space. Thanks for all the info guys, I may have to rethink this.
[Re: IMGTX]
#788336
08/31/10 11:13 AM
08/31/10 11:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It can open a can of worms with steering geometry.
Assuming you have power steering. Ideally you would want to move the box keeping the center line of the input shaft parallel to the center line of the car. Then lengthen the center link to compensate. This would cause one tie rod end to be shorter than the other. Lengthening the space between the idler arm end and tie rod end could help
Another thing to consider when you start lengthening & shortening tierods your gonna create bump steer issues..
Find some headers that fit...
[Re: 1_WILD_RT]
#788337
08/31/10 11:22 AM
08/31/10 11:22 AM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
True.
[Re: Red383]
#788340
08/31/10 04:50 PM
08/31/10 04:50 PM
Posts: 2,826 NY usa
540challenger
NY usa
This is I am installing a 5.7 Hemi in an A-body, and I'm looking for a way to keep the power steering. With TTI headers, it looks like I can make it work if I move the steering box over a bit. I will need to do more measuring yet, but I wanted to get some feedback from others before I cut the mount off. I wonder what the factory tolerances were on this mount. Probably +/- 3" ;-)
Manual steering is probably what will happen, I'm just looking for options.
Wow thats alot of movin, Maybe try an aftermarket rack and pinion with and aftermarket steering colunm that way you could use a D-shaft and universal joints to move the shaft around the exhaust.
