Can 5 on 4" axles be drilled to 5 on 4.5"? #78758
06/23/08 02:01 PM
06/23/08 02:01 PM
Missouri
NFURY8 Offline OP
super street
NFURY8  Offline OP
super street
Missouri
Is there enough material on a 70 Duster axle to be drilled out to 4.5"? I think it is an 8 3/4". I haven't seen the car and am trying to help a friend convert to disc brakes from a distance. He thinks it was originally an 8 1/4" axle.
C-Body DryDock Bigger is Better!
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: NFURY8] #78759
06/23/08 02:02 PM
06/23/08 02:02 PM
Table Rock Lake Missouri
furious Offline
furious  Offline
Sure, we used to do it all the time, before there were so many options.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: furious] #78760
06/23/08 02:26 PM
06/23/08 02:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Best deal is to weld the old holes shut and then drill the new pattern to accept 1/2" screw in studs rather than the knurled press ins. That way there is very close to the same amount of meat left between the stud and the lip of the flange as there was on the old 7/16 knurled press in studs.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: MoparforLife] #78761
06/23/08 08:06 PM
06/23/08 08:06 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Have some truck axles cut down, properly looking at comparable money and you end up with a better product and can sell the SBP axles to someone who wants them, probably come out money ahead.
Careful, your character's showing!
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: mopar346] #78762
06/23/08 08:56 PM
06/23/08 08:56 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
You've been given good advice.
If you have the SBP axels redone, you also
need to have the drums redrilled too.
Runs about $125.00 to do two axels & drums.
If you have truck or "C" body axels cut and
resplined, yes you do end up with stronger
axels,but it does require changing over to
"B" or "C" body brakes also because the axles
will sit out a bit more than the "A" axels do.
Phil Saran Parker, Colorado
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: Phil Saran] #78763
06/23/08 10:54 PM
06/23/08 10:54 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My 71 Duster had the axles redrilled to the 4.5 pattern. The 4.5 pattern put the holes right at the edge of the axle, I wasn't too crazy about it.
Sheldon
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: RUNCHARGER] #78764
06/24/08 08:48 AM
06/24/08 08:48 AM
Upper Midwest
Upper Midwest
Sheldon
Exactly why I prefer screw in studs. There is very near as much meat around the stud as with the pressed in small suds on the 4" pattern.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: NFURY8] #78765
06/24/08 10:46 AM
06/24/08 10:46 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A 70 Duster had a 7-1/4 or an 8-3/4. You need to know what he has first. The cheapest alternative is a junkyard 8-1/4 that is already big bolt, but watch the gear ratios. The one I pulled for somebody else was a 2.45:1 (no, that's not a typo). I don't like the redrilling for several reasons, but the big one is that now you have brakes that are already hard to get drums for, but if you need them you'll have to get them drilled out, too.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: Jim_Lusk] #78766
06/24/08 01:33 PM
06/24/08 01:33 PM
Missouri
NFURY8 Offline OP
super street
NFURY8  Offline OP
super street
Missouri
Looks like he is now giving new axles from Moser a strong consideration. Thanks for the info guys!
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: NFURY8] #78767
06/25/08 01:19 AM
06/25/08 01:19 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock high-strength 5 x 4 1/2" A-body axles with bearings and studs installed.
E-mail me if you are interested.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: MoparforLife] #78768
06/25/08 02:53 AM
06/25/08 02:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sheldon
My Barracuda is drilled and has the screw in cap screws for lugs. Mazzolini did that for $90 in 1993. From what I know now, I'm allmost sure he subbed that out to Sutton Engineering. I've put about 50K very hard miles on them over that last 15 years!!
The rear drums are getting pretty warn though. I do run a adjustable MP brake valve though and 11.75 front disks.
My use/abuse and milage would cover about 98% of the A-body owner here though.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: NFURY8] #78769
06/25/08 10:09 AM
06/25/08 10:09 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I would go with DR Diff over Moser and I would NEVER redrill stock flanges. For a couple of hundered bucks more you can have some much stronger axles. -Bob
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: BobR] #78770
06/25/08 10:35 AM
06/25/08 10:35 AM
JCFcuda Offline
JCFcuda  Offline
Theres nothing wrong with redrilling the axles.
I used bolts 4 years on the street,4,ooo miles/yr . The last year at the strip, I ran 10. 80s. 10.5 slicks.and did not have any issues. I welded the holes redrilled the holesin the axles and drums.
Re: Can 5 on 4" axles be drilled to 5 on 4.5"? [Re: JCFcuda] #78771
06/25/08 08:23 PM
06/25/08 08:23 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I guess the tech inspector never looked. If you use a locked rear or run faster than 10.99 you must use aftermarket axles for most if not all sanctioning bodies. -Bob
