mini starters #786923
08/29/10 01:04 PM
08/29/10 01:04 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Any experience/advice/suggestions on installing a mini starter on a 340/727?
Which one/brand/mfg is best?
I got this idea from another thread on how to get fuel up to the bowl after not starting the car for a while. Faster revs makes fuel pump work faster so less strain/drain on battery cranking.
Driving modern convenience in classic beauty
Re: mini starters [Re: Darius] #786924
08/29/10 01:28 PM
08/29/10 01:28 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Always use a JY starter from about a 90 or newer Mopar V6 or V8. Never had a problem with one. and at 25/35 bucks a piece.
Re: mini starters [Re: MoparforLife] #786925
08/29/10 01:35 PM
08/29/10 01:35 PM
scratchnfotraction Offline
reman from napa seem to be good
also got them from our u-pull for 14$ and had one rebuilt 65$ local starter/alt shop
you could check with a local shop that rebuilds as they will have a good price most times
spin my 440 pretty fast,same on my 318 truck
i also up to the mini alt on the 440 truck in the sig pic
Re: mini starters [Re: scratchnfotraction] #786926
08/29/10 10:47 PM
08/29/10 10:47 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Nipendenso is the brand. As for pumping fuel to the carb. Yes it will shorten the time but not really fixing the problem.
