Re: Brake lights not working, but turn signals are???
[Re: buildanother]
#786852
08/30/10 10:15 PM
08/30/10 10:15 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
First, check the bulbs. I'm amazed how many vehicles I see with one of both burned out. Next, since your truck should have separate bulbs for the brake lights but the 3rd works (proving out the fuse and switch), check for power at the bulbs. If there is no power at the bulbs, check under the back. The most common fault is where someone hacked into the rear harness for the tow lights. Then where the harness follows along the frame, forward to the cab. Additions and damage should point to the areas to inspect closer. Last, get the wiring diagram and find where the wiring goes through the bulkhead. Check for power there. If you still have no power, it's going to be under the dash.
[Re: wkroncke17]
#786853
08/30/10 11:50 PM
08/30/10 11:50 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
You've heard of Canbus? If I remember right, and I'm not sure I do, even the lights run through the instrument cluster due to canbus. I've heard of some VERY weird seemingly unrelated problems solved by replacing the instrument cluster on some of these newer trucks. FWIW, YMMV, no warranty express or implied in this post.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
