No fuel in carb-(non hijack question) #786837
08/29/10 10:02 AM
08/29/10 10:02 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
A lot of great discussion on the other thread an this subject but I didn't want to hijack it. I have two questions for you all after reading that thread.
1. Where would you mount an electric "boost" pump on a 69 Dart with a 340 and which brand pump would you use.
2. Is there any particular brand mini starter that is better/worse than another (727 trans)
This is timely because I believe my starter is going out on me anyway.
Driving modern convenience in classic beauty
Re: No fuel in carb-(non hijack question) [Re: Darius] #786838
08/29/10 01:31 PM
08/29/10 01:31 PM
Tampa, Fl.
tampacuda69 Offline
tampacuda69  Offline
Tampa, Fl.
In referance to my '69 barracuda 235/60 X14 Front
245/60 X14 Rear
1. I mounted a Carter Street Pump (Summit # CRT- P4070)just forward of the front leaf spring
mount. The bottom of the pump's elect.
connections are about 1&1/4 below the frame
rail. I have never had a problem with this
location bottoming on speed humps or drive
ways.
2. I used an original equipment Dakota starter
( junk yard purchase). TTI headers on a 340.
No problems.
