Need you home repair thoughts on the fuel sending unit #786176
08/28/10 06:49 AM
08/28/10 06:49 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I bought one of those 3/8" fuel sending units for my 69 Charger. my 5/16 unit failed (the float sunk) and I figured since I had it out, I should upgrade it to the new one (didnt chuck out the old one yet). I filled up my tank and the gauge only shows 1/3 full....The float was new and didnt sink in water...the gauge is restored from AutoInstruments and doesnt even have 100 miles on the new cluster. I have soldered a ground wire to the fuel supply pipe and then grounded it directly to the chassis near the shock mount
What do I have to do to make that sending unit read correctly? Anyone have a schematic and a list of parts that I can solder in or wind up and make it work.....should I take the guts from my 5/16 sending unit and put it in the new one?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Need you home repair thoughts on the fuel sending unit [Re: Pyper70] #786177
08/28/10 07:33 AM
08/28/10 07:33 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
It's all in grounding the dash and the sending unit. A dash ground will usually mess with the temp gage too.
