Odometer Gurus - Help the Dumb #785656
08/27/10 04:50 PM
08/27/10 04:50 PM
S IL
1BaadBee Offline OP
1BaadBee  Offline OP
S IL
71 B Body rallye dash odometer, took it out and replaced the numbers. Can't it get to align or work correctly. How is it done. Thanks
Re: Odometer Gurus - Help the Dumb [Re: 1BaadBee] #785657
08/27/10 06:00 PM
08/27/10 06:00 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
69 B rallye took me about 90 minutes to figure out. I took it out and reset the new odo to the old odo. You have to set those teeth in the same angle. Its a little difficult. Gentry at AutoInstruments walked me through it...but if you hold it and move the tenths wheel around it should rotate the "ones" place...and with time when the "ones" go to zero out...the "tens" place will start to move. Fiddle around with it, you'll get the hang of it
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
