B-body tilt steering column question #784593
08/26/10 11:13 AM
08/26/10 11:13 AM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
71 RR console shift car. I want to put in a tilt column. Can a tilt column from a column shift car be converted over to console?
'72 Road Runner
'72 Dart Swinger 340
'12 Challenger R/T
Re: B-body tilt steering column question [Re: sco440] #784594
08/26/10 01:15 PM
08/26/10 01:15 PM
Poplar Bluff, Missouri
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Chrysler didn't offer tilt colums with floor shift. But GM did, and you can use parts from a GM column with floor shift and tilt and make it work for you. Don't forget that you will need the shaft to steering box adapter for tilt as standard columns are different as is the turn signal wiring. Good luck with your swap.
Back from hiatus
