cnc ported stealth heads #784535
08/26/10 10:28 AM
08/26/10 10:28 AM
belleville,illinois 62221
dougdodgeman Offline OP
Does anyone know if the cnc ported stealth heads from 440 source are delivered with a competition valve job. These were new in the box, but are now installed on the engine and awaiting a dyno run.The question arose about the valve job, which then caused me to post this question.Btw, these were purchased a little over a year ago if that helps. Thanks
Re: cnc ported stealth heads [Re: dougdodgeman] #784536
08/26/10 11:13 AM
08/26/10 11:13 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't own a set, but believe that the MCH (Modern Cylinder Head) CNC work does include valve seat & guide work, along w/ the porting. You should be fine.
