Good Day All
I have recived many responses to by 383 overheating question...Thanks to All.
Some of the responses have lead me to ask more questions: Is there a source for the radiator hose springs? These are the springs that prevent the lower hose from collaspsing.
Which would move more collant, a six or eight blade impeller? I realize that pulley diameter affects the speed but if all else is the same, which would move more?
Does a fan clutch move more air that a fixed fan? If so is there a source for factory type fan blades?
Would the addition of a 'pusher' fan in front of the condensor assist or impede the engine fan?
Would changing to an aluminum water pump housing and water pump aid noticably in heat dissapation? If so, is there a source for sand cast parts that resemble the factory iron parts? I'm trying to keep the engine bay as stock as possible.
As always thanks for your insight.
Omni
