360 Compression/Head Advice #78406
06/22/08 03:46 PM
06/22/08 03:46 PM
The Motor City
Stew4706 Offline OP
Stew4706  Offline OP
The Motor City
I have a 79 360 with an rv cam and a 4bbl and I would like to wake it up a little bit. It is currently running the factory compression @ 8.5:1 - has anyone swapped on Magnum heads? If so where will the compression end up??
Thanks Moparts!!
Re: 360 Compression/Head Advice [Re: Stew4706] #78407
06/22/08 03:53 PM
06/22/08 03:53 PM
jonesboro, ark
ramcharger82 Offline
jonesboro, ark
think your compression may be around 7.5 or so. i have been told you can gain another point in compression. i am thinking of doing a magnum swap as well. alot of info in tech pages. check em out
Built not Bought
Re: 360 Compression/Head Advice [Re: Stew4706] #78408
06/23/08 06:20 AM
06/23/08 06:20 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I am running magnum heads on my 360 but I also am using high compression pistons and had the deck machined so the pistons sit zero to the deck. This is giving me 10.6:1 compression with a 0.040" thick head gasket.
On of the best features of the magnum heads is when you get the pistons to the top of the deck you can establish an ideal quench which makes the engine very detonation resistant. I run my engine on 89 octane and can run 87 in a pinch but would need to slow down the advance in the distributor to run the 87 all the time.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 360 Compression/Head Advice [Re: dgc333] #78409
06/23/08 08:46 AM
06/23/08 08:46 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
doubt you're at a true 8.5:1. when I did the math after measuring my shortblock and stock heads, and it was about 7.8:1. mag heads and thin MP gaskets would bump me up to about 8.6:1.
2017 Grand Cherokee Overland
