shaving heads,how much #783470
08/24/10 10:24 PM
08/24/10 10:24 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
How much can you shave off of a set of 302 heads on a 318 with stock bottom end and cam before there is a clearence issue?
Re: shaving heads,how much [Re: moparborn] #783471
08/24/10 11:27 PM
08/24/10 11:27 PM
Under My Car
Mopar_Country Offline
Under My Car
If your trying to up compression, I believe with the 302 heads you should be at 9 to 1 already. You would not want to go much higher if this is a street engine running on pump gas IMO.
Re: shaving heads,how much [Re: Mopar_Country] #783472
08/25/10 10:14 PM
08/25/10 10:14 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Clearance of what?
Shaving will affect your pushrod length or at a minimum lifter preload, intake port alignment and watch the alterator alignment too.
Re: shaving heads,how much [Re: Magnum] #783473
08/28/10 04:24 PM
08/28/10 04:24 PM
Pa. U.S.A.
Pa. U.S.A.
I would like to get to around 9.5.
I am interested in the valve to piston clearence.
Pushrod lenght,I can work with as with alt.
