Re: Anyone tap a cylinder head? [Re: GwaiiEagle] #780648
08/23/10 08:23 PM
08/23/10 08:23 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
you might try tapping it to 7/16,might be just enough to tap good!,DONT break off a tap in the head!
Re: Anyone tap a cylinder head? [Re: rhad] #780649
08/23/10 08:44 PM
08/23/10 08:44 PM
scratchnfotraction Offline
remove the header before tapping the hole to 7/16 or helicoil
if you dont get it straight,and mess it up,the head will need to be replaced
to helicoil it you need the correct size drill bit with the helicoil kit
the kit has a tap and coils and the coil install tool
remove header,drill to size,tap hole,install helicoil with some rtv on the outside of the coil,put header back on and then use the stock size bolt with rtv on it..LET THE RTV CURE OVER NIGHT!...add water to rad and run engine and check for leaks
or like said,use a 7/16 tap and use a larger than stock bolt after drilling the header flange for the bigr bolt
Re: Anyone tap a cylinder head? [Re: scratchnfotraction] #780650
08/23/10 10:05 PM
08/23/10 10:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Why are you guys talking 7/16? I suggest a 3/8. Jees the original is only a 5/16 so why would you recommend going to 7/16??
Re: Anyone tap a cylinder head? [Re: MoparforLife] #780651
08/23/10 10:23 PM
08/23/10 10:23 PM
my bad..I used what he said
i get the bolt size and the wrench head size mixed up a lot
your right 3/8 duz sound better
Re: Anyone tap a cylinder head? [Re: scratchnfotraction] #780652
08/23/10 11:24 PM
08/23/10 11:24 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i also thought the original size was 3/8!!!
