Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780601
08/25/10 11:13 AM
08/25/10 11:13 AM
64MAX Offline
64MAX  Offline
Many, many years ago (1996) I bought a cable from a company called Service Express Company at 8909 H Street in Omaha, Nebraska 68127. I spoke to a man named Dan Bloomer and they made me a cable to fit a Mopar Tach Drive distributor and a Stewart Warner 535 AH-D. The seemed to know exactly what I needed and sent the cable right out. It's still in a box in my garage. Best of luck. Tom
Re: mechanical tach and cables - help [Re: 64MAX] #780602
08/26/10 04:42 PM
08/26/10 04:42 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
yea, that is kinda what i did also but i wanted to know where i can get the "correct" stuff if it doesn't hold up. i got the msd adaptor pulled the little roll pin and sanded it down on the belt sander to fit the distributor, put the roll pin back in and slid them together. well the 1st time i disconnected it the brass piece had split in 2 so i silver sodered it with low temp soder and put it back together. seems to be ok for now.
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780603
12/13/10 04:44 PM
12/13/10 04:44 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Thanks Danny - I did contact Pegasus .. waiting to hear back - they have a adapter on there site but it is for the opposite situation I have.
Have my that they have another solution !
Here is pic of the whole thing.. you can see what I am trying to accomplish.
cool stuff.does anyone know what the device is called that makes the tachometer cable and the engine speed limiter cable run parralell to each other?who made them and what was the brand name.i have the same setup as in the pic, but with a T-brass splitter for the overspeed governor.does any of you guys have any info on that parallel cable splitter.thanks
Re: mechanical tach and cables - help [Re: cuda-sweden] #780604
12/17/10 07:54 PM
12/17/10 07:54 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Re: mechanical tach and cables - help [Re: cuda-sweden] #780605
12/18/10 04:14 PM
12/18/10 04:14 PM
USA
SSAAHemiFan Offline OP
USA
I got mine last year, from a old speed shop - new in the box wrapped in newspaper from 1971 - he couldn't believe someone still wanted to use one.
He actually had to go back and find a 1972 catalog to price it ! I tossed him a extra $30 on top for dinner as I was so happy to have it
He called it a "dual drive cable splitter" - Mine has Stewart -Warner stamped right into it.
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780606
12/18/10 05:25 PM
12/18/10 05:25 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
great,thanks ill keep looking.good to know that stewart warner made them.
Re: mechanical tach and cables - help [Re: cuda-sweden] #780607
12/18/10 07:45 PM
12/18/10 07:45 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Not sure if these are adapters for changing mechanical tach cables or not.
http://www.stewartwarner.com/Catalog/flex-end.html
