400 crankshaft ? #779851
08/21/10 07:39 PM
08/21/10 07:39 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
hello, did the 400 ever come with a Forged steel crankshaft from the factory? I had always been under the impression that they were all cast( at least the dozen or so I have disassembled) but saw in some book today that showed a parts listing claiming a steel crank.so, did they? and another question, I need a external balance damper for a 383 cast crank, I have a external damper from a external balance 400/440, will it work on the 383? Thanks
Re: 400 crankshaft ? [Re: Tom Fox] #779852
08/21/10 07:57 PM
08/21/10 07:57 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I pulled a steel crank 400 out of a 4-speed '78 Dodge P/U truck.
Bearings were all std., and had late '77 date on the back, so I'm assuming it was original equipment.
Re: 400 crankshaft ? [Re: Tom Fox] #779853
08/21/10 11:26 PM
08/21/10 11:26 PM
AndyF Offline
AndyF  Offline
400 with four speeds were supposed to have forged cranks in them. No idea if that really happened or not. There certainly were some 400 motors built with forged cranks but probably not a big percentage.
Re: 400 crankshaft ? [Re: AndyF] #779854
08/22/10 01:24 AM
08/22/10 01:24 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
How about using a 383 forged crank? Same stroke. Just smaller thrust bearing surface.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: 400 crankshaft ? [Re: AndyF] #779855
08/22/10 01:25 AM
08/22/10 01:25 AM
abodyman Offline
super street
abodyman  Offline
super street
The 400 I pulled from a 78 Dodge truck, came with a forged crank.
4-speed...Was a pleasant surprise!
Re: 400 crankshaft ? [Re: abodyman] #779856
08/22/10 09:04 AM
08/22/10 09:04 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
From what i know the 400 4-speed cars and trucks came internally balanced with steel cranks. Should pretty much be the same crank as a 383 steel one. I dont think there is such thing as an externally balanced 400 flywheel, for instance.
Re: 400 crankshaft ? [Re: kilroy] #779857
08/22/10 09:52 AM
08/22/10 09:52 AM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
what I have is a newly acquirered car with a '71 383 cast crank engine. it has a mech. vibration at about 2000rpm, and it has a int. steel crank balancer on it now. I want to put a proper ext. balance balancer on it and see if it goes away.I do not have a spare balancer with the correct pt# for a '72 383, but I do have a couple of 400/440 cast crank one's and was wondering if ANY cast crank balancer should be correct?
Re: 400 crankshaft ? [Re: Tom Fox] #779858
08/22/10 01:55 PM
08/22/10 01:55 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
400s have same rod/stroke as 383 but much bigger piston. 440 has longer stroke/bigger piston than 383. Plus factory balance is pretty loose. If you already have wrong balancer and a vibration I would go ahead an try the other 400/440 balancer all you would be out is your time, because like you said its already wrong.
Re: 400 crankshaft ? [Re: kilroy] #779859
08/22/10 01:56 PM
08/22/10 01:56 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Was this a balance motor or just a "put together"? Could be a driveshaft vibration.
Re: 400 crankshaft ? [Re: kilroy] #779860
08/22/10 05:10 PM
08/22/10 05:10 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
not a drive shaft problem, does in sitting in park. def. engine related. already tried a 400/440 ext. balancer. vibration was about the same.torque converter has no weights on it and I am assuming it is also wrong. am going to get a new one for 383 external to be sure and I want to replace it anyways.one torque converter fit's 383/400/440 ext. balance, so I would think the same would be true for a balancer, one ext. balancer would fit any ext. 383/400/440
Re: 400 crankshaft ? [Re: Tom Fox] #779861
08/22/10 10:28 PM
08/22/10 10:28 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Yes the balancer and convertor/flywheel on any motor are either neutral balance for internal balance motors or are both have to be externally weighted for external. So yes you need a external balance convertor (weighted) and external balancer.
Two other things to think about
1. Someone has internally balanced motor thats why it has internal balance balancer/convertor but then you wouldn't have any vibration.
2. It was rebuilt without concern to balancing the components and no balancer or convertor will put the vibration to rest without taking motor down and taking rotating assembly to machinist to balance.
Re: 400 crankshaft ? [Re: kilroy] #779862
08/22/10 10:30 PM
08/22/10 10:30 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Oh and if you dont want to buy a new convertor mopar (and Im sure others) sell weight kits with template to make a convertor ext. balance. Ive used one with great success.
Re: 400 crankshaft ? [Re: kilroy] #779863
08/22/10 10:58 PM
08/22/10 10:58 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
383 is original '71 bottom end.just a bigger cam/head work. was a race car since the late 70's. has a high stall convertor that I want to change anyhow. just would like to know if the 400/440 ext balance harmonic balancer that I have will work? or do I have to use the correct pt# balancer that the 72' 383 calls for? I don't want to hunt that one down just to find out the only difference is the pt #.
Re: 400 crankshaft ? [Re: Tom Fox] #779864
08/23/10 12:54 AM
08/23/10 12:54 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
440 and 400 cast cranks do not use the same balancer. The 71 cast crank 383 uses the same balancer as the cast 400. I have a few. PM me if you need one.
Most 400 4-spd motors had steel cranks. Have had a couple 77/78 400 4-spd trucks with cast cranks and a few with steel. All my earlier 4-spd motors were steel cranks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 400 crankshaft ? [Re: moparmarks] #779865
08/23/10 01:07 AM
08/23/10 01:07 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
yup, I pulled a externally ballanced 'wheel off a 1977 400 cast crank truck engine...worked fine on my 440.
