What causes an intake valve to break at the valve stem. #778374
08/19/10 05:27 PM
08/19/10 05:27 PM
IN
67Dart383 Offline OP
IN
I've got a 67 Dart with a 383 that has been professional built and I had an intake valve on the number one cylinder break right at the valve stem keeper. What the heck would cause something like that? Thanks Guys
Re: What causes an intake valve to break at the valve stem. [Re: 67Dart383] #778375
08/19/10 05:46 PM
08/19/10 05:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Coil bind and bottoming out the spring on shims or Valve guide can do it!
Re: What causes an intake valve to break at the valve stem. [Re: Dodgem] #778376
08/19/10 06:54 PM
08/19/10 06:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: What causes an intake valve to break at the valve stem. [Re: MoparforLife] #778377
08/20/10 09:28 AM
08/20/10 09:28 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
All of the above along with lack of valve control by the valve springs. Springs not having the correct loads and bouncing the valve.
logan426
Re: What causes an intake valve to break at the valve stem. [Re: MLR426] #778378
08/20/10 10:03 AM
08/20/10 10:03 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
were the valves replaced with one piece stainless when the motor was rebuilt? factory type valves are 3piece.
Re: What causes an intake valve to break at the valve stem. [Re: old_racer] #778379
08/20/10 04:01 PM
08/20/10 04:01 PM
IN
IN
I had the valve springs pressure checked and they came in at 125 psi which should be enough for the 284/484 cam I am running. Just fyi. I got marks on a few pistons where the exhaust valves have hit them. The motor was professionally built and the piston to valve clearance was o.k. I suspected the springs are bad even though they check out o.k. I guess I should try a heavier spring. The valves are stock not stainless also.
Re: What causes an intake valve to break at the valve stem. [Re: 67Dart383] #778380
08/20/10 04:58 PM
08/20/10 04:58 PM
Upper Midwest
Upper Midwest
Not talking about pressure. Talking about the travel of the spring. There should be at least .060 more travel in the spring than the full lift of the valve to the point where the spring goes solid. Preferably closer to .100 more travel. Sounds like you possibly could have floated the valves too. Actually the spring should have had enough travel in them but if you floated them that is a different story. How many RPM's were you trying to spin??? Or did you have shims installed under the springs to increase the pressure?? Shims are to be used to adjust installed height not to increase spring pressures.
BTW this was caused by coil bind.
Re: What causes an intake valve to break at the valve stem. [Re: MoparforLife] #778381
08/20/10 10:39 PM
08/20/10 10:39 PM
IN
IN
You guys have been a huge help. Before this happened I was having problems with it, it would stop pulling at 6000 rpm sometimes in first and sometimes in second gear. It wouldn't miss fire or anything it would just totally stop pulling. I thought I had a fuel pressure or ignition problem but after braking this valve and seeing the marks on the other pistons where the valves have hit them I must have been floating the valves. The valve springs are Mopar performance springs that where matched for that cam back in the day but even though the motor only has about 1000 miles on it the springs are 20 years old. They didn't sit with rocker arm pressure for that long but with this happening and there age factored in it I will change them. Plus I don't have a lot of faith in some of the Mopar performance parts. Thanks again for all the help and if anybody has anymore wisdom to share feel free to chime in.
