Re: Custom Pistons, did I pay to much??
[Re: Hyper Henry]
#777945
08/19/10 10:37 AM
08/19/10 10:37 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Yes you did. Several memebers here, including myself could have saved you some coin. In reality, the manufacters dont want to deal direct with the public, they would much rather have one of their dealers spec it all out and just send them the engineering sheet, a quick phonecall or email, and poof, out go the pistons. ( or rocker arms, rods, cranks, whatever specialties etc) However, they are greedy. When they get a chance to sell at those prices, they will.Which irks me, but thats another whole story we wont get in to...
RIP Monte Smith
[Re: Performance Only]
#777947
08/19/10 10:45 AM
08/19/10 10:45 AM
Posts: 8,165 Left Coast
BobR
Left Coast
you should have ordered them through me or one of the other dealers on here to save some money.
How much will he save?
[Re: Hyper Henry]
#777949
08/19/10 12:29 PM
08/19/10 12:29 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Like Andy said, there are plenty of options for custom pistons. Some manufacturers actually have multiple forgings that they start with and the forgings themselves are different prices. When you start tricking them out with the best pins, rings, skirt finishes, lightening programs, lateral or vertical gas ports the price can escalate real quick. Ive heard of guys paying in excess of $1500 for top of the line stuff. So you may not be that far off. Now if your particular piston was available as a "shelf" pistons, thats another story...you definitely paid too much. That means that they already had a file for your dome, crank, etc. combo and they simply made you a set without much design. Tell us what some of your options are.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#777950
08/19/10 12:33 PM
08/19/10 12:33 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my custom Diamonds I ordered from a dealer here on the board they where custom domes with pins,rings and oil support rails and was less than 1000.00
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#777953
08/19/10 10:29 PM
08/19/10 10:29 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Right at $800 for Custom Diamond wedge pistons...Had a small dome, came with pins, no rings, not fancy lightning or gas ports...just plan ole pistons... From a board member of coarse......
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Hyper Henry]
#777954
08/19/10 11:11 PM
08/19/10 11:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I picked up a set of CP pistons... I had to send them my W-9 head so they could scan it then they built the pistons at 14.1:1... ultra light... they came with pins and the support rails, gas ported... no rings and that was $1000.... I had to get 4 more after I blew up the engine and the 4 pistons were $420 which they built from my original work order
[Re: BobR]
#777957
08/20/10 06:08 PM
08/20/10 06:08 PM
Posts: 4,209 New York
polyspheric
New York
That's only 1 advantage
#2 is you're spending money with a member of the community
#3 is that they are much more likely to spot a missing dimension, bad plan, typo, nice feature you didn't think of, so you get free advice
Boffin Emeritus
[Re: polyspheric]
#777958
08/22/10 12:28 AM
08/22/10 12:28 AM
Posts: 345 Ontario, Canada
Hyper Henry
Ontario, Canada
Ok guys, can you guys that say you can get me better prices pm me then on custom pistons I am leaning towards a set of KB that I can make work but not optimal but price is right Specs are: 4.375 bore, 4.250 stroke, 7.10 rod,.990 pin, 1.480 compression distance, 10.715 block deck height, standard rings, Eddy heads with 70 cc chambers and 2.25/1.84 valves. looking to get as much compression as possible and running alcohol. Derrick
[Re: Hyper Henry]
#777960
08/22/10 08:04 AM
08/22/10 08:04 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
.....7.10 rod,.990 pin, 1.480 compression distance,....
I ordered custom pistons with those basic dimensions from Diamond w/rings for about $800. That was 3 1/2 years ago. Like Andy said, it was simply a stocking piston with an adjusted CH.
[Re: AndyF]
#777961
08/22/10 08:37 AM
08/22/10 08:37 AM
Posts: 2,091 Delray beach, Florida
Performance Only
That sounds like a shelf piston with a pin height change. Diamond does that stuff for shelf pricing plus a small charge to change the pin height.
it won't be a change to shelf stock for two reasons, the valve diameter and wanting "as much compression as possible" makes it a domed piston with larger than shelf stock valve notches. for that application he may want better than a standard wrist pin also.
machine shop owner and engine builder
#777962
08/22/10 10:19 AM
08/22/10 10:19 AM
Posts: 3,441 Mo.
supercomp
Mo.
Just got custom Diamonds from Performance Only. Flat top with .990 H13 pins, 1.145 C.H., lateral gas ports, .043 AP top, 1/16 napier 2nd, 3/16 low tension oil. I wouldn't run this ring setup without a vacuum pump, JMO. .265 valve reliefs for 2.200 intake, 1.81 exhaust valves. Also K1 6.700 rods and 4.250 K1 crank. Dan will treat you right at a fair price without the attitude.
