DIY alignment #775740
08/17/10 09:19 AM
08/17/10 09:19 AM
SD
Z
zrxkawboy Offline OP
Z
SD
Does anyone do their own alignments? I know there is equipment available, I just don't know if it's any good. Any recommendations are appreciated.
Sadly, there is no one in this small town that I trust to do a good alignment.
It's Swifty! Swifty, you toad sucker!
Re: DIY alignment [Re: zrxkawboy] #775741
08/17/10 09:30 AM
08/17/10 09:30 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I have been using a SmartLevel (caster/camber) and tape measure with two sharp sheetrock screws for decades!
Rick
Re: DIY alignment [Re: Rick_Ehrenberg] #775742
08/17/10 10:20 AM
08/17/10 10:20 AM
SD
Z
Z
SD
Thanks for the fast reply, Rick. Can you elaborate on the level that you use?
Thanks!
Re: DIY alignment [Re: zrxkawboy] #775743
08/17/10 10:51 AM
08/17/10 10:51 AM
Marlboro, NY, USA
Marlboro, NY, USA
It is just a digital Level that an outfit sold an adapter for called "Smart Camber". You just hold it against the rim (bead seat area). Nice part: You can "zero out" the floor camber.
Rick
Re: DIY alignment [Re: Rick_Ehrenberg] #775744
08/17/10 11:01 AM
08/17/10 11:01 AM
SD
Z
Z
SD
You mentioned caster, too...briefly, where is caster measured with this method?
I really do appreciate the help!
Re: DIY alignment [Re: zrxkawboy] #775745
08/17/10 11:05 AM
08/17/10 11:05 AM
Marlboro, NY, USA
Marlboro, NY, USA
Same as every alignment, by calculations during a "caster sweep" (turning wheels lock/lock).
Rick
Re: DIY alignment [Re: Rick_Ehrenberg] #775746
08/18/10 02:12 AM
08/18/10 02:12 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I use a method laid out here with my $40 camber/caster tool. Put the front cam all the way out and the rear all the way in. Adjust the rear cam until you have about 1/2degree negative camber. This is the most positive caster that you can get out of the parts you have on the car.
Of course, this is AFTER setting the ride height and BEFORE setting the toe (I like about 1/16-1/8" toe-in).
If the car pulls with this setup, then you can check the caster and adjust accordingly, but I haven't had to alter from this setup. I also set the ride height to have about an inch between the LCA bumper and the frame (I use a better point on the LCA to make both sides even. I also check from the frame to the floor - same spot).
Re: DIY alignment [Re: Jim_Lusk] #775747
08/18/10 11:32 AM
08/18/10 11:32 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I've tried a few times but after checking the work on a proper rack. I'll no longer do the final setting at home. You can not match the precision of a modern alignment machine.
It would take hours to duplicate and experienced technicians accuracy which can be done in under 20 minutes.
Re: DIY alignment [Re: Magnum] #775748
08/18/10 12:48 PM
08/18/10 12:48 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive had my car to every REPUTABLE alighnment shop in a 2 county area and its a joke,no one around here can do these old school front ends,I FEEL YOUR PAIN,i finaly found an oldtimmer that said "WELL ILL TAKE A LOOK ATER FER YA"he got it pretty darn close but still have a bump steer issue.
Re: DIY alignment [Re: bonefish] #775749
08/18/10 01:19 PM
08/18/10 01:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The actual bump steer geometry is not going to be changed with an alignment rack per se. You need a bump steer gauge and you need special tie rods or move the centerlink up or down using steering box shims and slotting the idler arm hole.
Or you can run one of those geometry corrected upper control arms that removes bump steer in B/E bodies.
On finding a good alignment shop... Try getting ahold of the local SCCA Solo II autocross club. Should be able to find that with a search online. Then contact them and ask them where all the autocross guys are getting their custom alignments done at. Alignments are a real big deal to those guys, so you have the power of group of a 100 local people looking for a good alignment technician.
Re: DIY alignment [Re: autoxcuda] #775750
08/18/10 09:46 PM
08/18/10 09:46 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
On finding a good alignment shop... Try getting ahold of the local SCCA Solo II autocross club. Should be able to find that with a search online. Then contact them and ask them where all the autocross guys are getting their custom alignments done at. Alignments are a real big deal to those guys, so you have the power of group of a 100 local people looking for a good alignment technician. [/quote HEY Steve where can i get one of those control arms?
Re: DIY alignment [Re: bonefish] #775751
08/19/10 02:42 AM
08/19/10 02:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Hotchkis sells a geometry corrected Upper Control Arm. It removes a bunch of the bump steer they measured in those cars.
Explained here: http://www.youtube.com/watch?v=VzxPWrdPlt0
Discription here: http://www.hotchkis.net/dodge_b_e_body_geometry_corrected_tubular_upper_aarms.html
Re: DIY alignment [Re: autoxcuda] #775752
08/20/10 08:03 PM
08/20/10 08:03 PM
Marlboro, NY, USA
Marlboro, NY, USA
Too bad it uses heim joints, kinda short-lived on the street. Plus, I've found bump-steer to be very minimal if everything is as-designed (read: blueprinted, as described above, not difficult at all).
Bump steer is easily measured at home, just a couple of 2x2' wood sheets and piano hinges, and a cinder block. Better with 2 setups. Also, any alignment rack is fine, just crank the bars all the way down, then measure toe at 1" intervals from full jounce (where you'll be with T-bars unwound) to full rebound.
Rick
Re: DIY alignment [Re: Rick_Ehrenberg] #775753
08/20/10 10:28 PM
08/20/10 10:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Too bad it uses heim joints, kinda short-lived on the street. Plus, I've found bump-steer to be very minimal if everything is as-designed (read: blueprinted, as described above, not difficult at all)...
A-bodies or E-bodies?
Re: DIY alignment [Re: Jim_Lusk] #775754
08/21/10 01:57 AM
08/21/10 01:57 AM
Jim The parking lot out here sure isn't level. What/where on the car do I measure (& jack it up if needed) to get the car level so the above procedure will be valid for me?
Re: DIY alignment [Re: RapidRobert] #775755
08/21/10 02:09 AM
08/21/10 02:09 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'm fortunate that I have a very level carport (it's more level than my garage). The problem is that you can't just jack the car up. The front suspension needs to be loaded. I'd suggest finding a friend with a level spot.......
Re: DIY alignment [Re: Jim_Lusk] #775756
08/21/10 02:19 AM
08/21/10 02:19 AM
yeah I forgot about it needing to be loaded. Well if I put tiles under all 4 wheels where would I measure?
Re: DIY alignment [Re: RapidRobert] #775757
08/21/10 02:24 AM
08/21/10 02:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
In order to determine the levelness of your setup you need to span them with a known, flat board or steel beam and use a level. Until you have the ride height set there really is no way to determine that the car is truly on level "ground" using the car. You also need to make sure you are level front to rear.
Re: DIY alignment [Re: Jim_Lusk] #775758
08/21/10 02:32 AM
08/21/10 02:32 AM
Sounds like I need to string it and hang a mini bubble gauge made for that on each of the 4 strings. Would that suffice?
Re: DIY alignment [Re: RapidRobert] #775759
08/21/10 02:40 AM
08/21/10 02:40 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, if the string is tight.
