Page 39 of 46 1 2 37 38 39 40 41 45 46
Re: Taking it to the next level? Wow! [Re: gtx6970] #77522
08/11/08 10:29 PM
08/11/08 10:29 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
If I may ask, if the trim rings are on it, then shouldn't the valve stem extensions also be on it.
Also , if the rings were installed ( aka - dealer prepped ) then also shouldn't the additional trunk items be installed
There you go Bill!!! The perfect opportunity to go in next year with your entry and knock us aside! I suspect however that you might be one of those individuals who posses this infinite wisdom and knowledge that never seems to make it into the reality of a restoration. In fact, most of it is wasted in mere words or typed skepticism on the forums. Just out of curiosity, were you able to re-evaluate the incorrect statement you made (earlier in this thread) about A/C upper radiator hoses and their applications?
Re: Taking it to the next level? Wow! [Re: ECS] #77523
08/11/08 10:40 PM
08/11/08 10:40 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
[quote Just out of curiosity, were you able to re-evaluate the incorrect statement you made (earlier in this thread) about A/C upper radiator hoses and their applications?
mmmmm, don't think so.
Re: Taking it to the next level? Wow! [Re: gtx6970] #77524
08/11/08 10:48 PM
08/11/08 10:48 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Let me help you on this one Bill since you obviously decided to conclude your research on your first finding. There were as many as four different upper hoses that could be incorporated on an A/C equipped vehicle. (Not the single unit you incorrectly said was used for ALL applications.) Comforting to see you at least knew about the one!
Re: Taking it to the next level? Wow! [Re: ECS] #77525
08/11/08 10:50 PM
08/11/08 10:50 PM
It's a dry heat
It's a dry heat
It was a simple question , not a jab so lighten up.
As I REALLY don't care what your car did or didn't score.
Re: Taking it to the next level? Wow! [Re: gtx6970] #77526
08/11/08 10:51 PM
08/11/08 10:51 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Of course not ol' buddy....of course not.
Re: Taking it to the next level? Wow! #77527
08/11/08 11:04 PM
08/11/08 11:04 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Ok....back to the "items delivered in the trunk"....Were 14" Magnum trim rings also in the trunk upon delivery?
As I stated...I knew full wheel covers were, but trim rings as well?
That's a lot of junk in the trunk
So Dave...How did the car score?
CHECK OUT MY NEW WEB SITE !
Re: Taking it to the next level? Wow! [Re: anlauto] #77528
08/11/08 11:23 PM
08/11/08 11:23 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Hi Alan,
Many combinations of assembly were found on these cars. I have pictures of cars from the factory with the trim rings on and some that were off. We obviously chose to take the “correct route” that facilitated our desired appearance. We don't know the points as Keith did not have the final tally. He did state that we came as close to a perfect score as possible and the deductions amounted to "quarter points" regarding the total percentage. One of our plug wire boots had a half inch split and some imperfections were found on the driver's side chrome reflective door bezel. (Mr. Bruce Herschberger has a perfect replacement being shipped and we have already replaced the wire boot.) Believe it or not, I did not take but a handful of pictures so I don't have any of significance to post. Tom Barcroft (He was part of our team) was kind enough to take hundreds of photos so I hopefully can get some from him. I am eagerly awaiting to see some of the pictures that others on this forum have stated they will post at a later time. I didn't get to see the updates on this forum until about a couple of hours ago. Around five this morning (we didn't get back till after midnight from Columbus) I received a call telling me my Father was rushed to the hospital for emergency brain surgery to stop internal bleeding. I have been there most of the day. It has certainly put a dampener on what should be a positive time right now. Also puts alot of things in perspective. Thanks for the comment.
Re: Taking it to the next level? Wow! [Re: ECS] #77529
08/11/08 11:35 PM
08/11/08 11:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Hi Alan,
Many combinations of assembly were found on these cars. I have pictures of cars from the factory with the trim rings on and some that were off. We obviously chose to take the “correct route” that facilitated our desired appearance. We don't know the points as Keith did not have the final tally. He did state that we came as close to a perfect score as possible and the deductions amounted to "quarter points" regarding the total percentage. One of our plug wire boots had a half inch split and some imperfections were found on the driver's side chrome reflective door bezel. (Mr. Bruce Herschberger has a perfect replacement being shipped and we have already replaced the wire boot.) Believe it or not, I did not take but a handful of pictures so I don't have any of significance to post. Tom Barcroft (He was part of our team) was kind enough to take hundreds of photos so I hopefully can get some from him. I am eagerly awaiting to see some of the pictures that others on this forum have stated they will post at a later time. I didn't get to see the updates on this forum until about a couple of hours ago. Around five this morning (we didn't get back till after midnight from Columbus) I received a call telling me my Father was rushed to the hospital for emergency brain surgery to stop internal bleeding. I have been there most of the day. It has certainly put a dampener on what should be a positive time right now. Also puts things alot of things in perspective. Thanks for the comment.
Dave:
Congratulations on the effort. As with any undertaking of this nature, it will be met with scrutiny. I did not make it to the Nats, so I cannot say first hand, but I am sure it was special judging by the glowing reviews that have been posted.
On a personal note, I hope all goes well with your Dad. I lost my father a few months ago and you are correct, puts all of this stuff in perspective. These cars may be rare and beautiful, but our loved ones(and ourselves), are truly one of one.
MB
Re: Taking it to the next level? Wow! [Re: HPMike] #77530
08/12/08 09:08 AM
08/12/08 09:08 AM
New Jersey Bada Bing
bremotorsports Offline
Dave,
First of all, I hope your dad is OK. Keep the faith.
Secondly, thanks for the behind-the-rope tour for the "world premiere". After all of our fact-finding and tech-based parts and process conversations along the way pertaining to the Challenger, there is no doubt that you and Steve and the whole team truly "walked the walk". A remarkable accomplishment!
Bill Rolik
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77531
08/12/08 09:38 AM
08/12/08 09:38 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
We too, would like to thank Dave for the over the ropes look at a fantastic restoration. Great job Dave, Steve, and Crew.
Brad Dorn
Doug Dorn
Dorn Autocraft
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Taking it to the next level? Wow! [Re: BradD] #77532
08/12/08 02:31 PM
08/12/08 02:31 PM
cataclysm80 Offline
cataclysm80  Offline
What keeps all the stuff in the trunk from falling down the crack between the quarter and trunk extension while the car is on the semi from the factory to the dealer?
Tav
Re: Taking it to the next level? Wow! [Re: cataclysm80] #77533
08/12/08 04:18 PM
08/12/08 04:18 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Tav
Tape.
Re: Taking it to the next level? Wow! [Re: cataclysm80] #77534
08/12/08 04:58 PM
08/12/08 04:58 PM
anlauto Offline
anlauto  Offline
Tav
I recently restored a 1971 440+6 Cuda which had chin spoilers on the broadcast sheet.
The original owner stated that the car never had any spoilers on the front, only the rear. I found no evidence of holes in the fenders, but the owner before me found a "new" chin spoiler jammed down between the trunk extension and 1/4 panel.
Re: Taking it to the next level? Wow! [Re: ECS] #77535
08/12/08 06:47 PM
08/12/08 06:47 PM
anlauto Offline
anlauto  Offline
Kind of ironic that we accept, paint drips, mis-aligned panels, inspection sploches, etc... as part the the "quality of the day" and no points are deducted, yet the judges deduct points for minor imperfections that could have easily been present on the day of delivery as well What a double edged sword
This thread has taught me that even if it was finacially possible for me to take a car to OE Gold status...I don't think that I would want to...The flack that goes along with it, would age me way too fast...
Re: Taking it to the next level? Wow! [Re: anlauto] #77536
08/12/08 07:47 PM
08/12/08 07:47 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
This thread has taught me that even if it was financially possible for me to take a car to OE Gold status...I don't think that I would want to...The flack that goes along with it, would age me way too fast...
Let me fix that for you:
This thread has taught me that even if it was financially possible for me to take a car to set the OE Gold status...
Re: Taking it to the next level? Wow! [Re: 70challrtse] #77537
08/12/08 09:39 PM
08/12/08 09:39 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I will start this question by saying I assume I am wrong.........but this photo illustrates the sway bar links are a single bolt style rather than the double studded end I THOUGHT was original. What's the facts on this issue. Awesome car, saw it at the Nats when it was up, so I didn't intrude.
Looking forward to your response.
Thanks, Kevin
Careful, your character's showing!
Re: Taking it to the next level? Wow! [Re: mopar346] #77538
08/12/08 09:58 PM
08/12/08 09:58 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
double studded end
Re: Taking it to the next level? Wow! [Re: ECS] #77539
08/12/08 10:03 PM
08/12/08 10:03 PM
moparr Offline
moparr  Offline
For those who didn't have the pleasure of seeing the challenger in person, I know that Five Star Production took a lot of film at the nats of this car. It will probably be available in his coverage of the showcars at the nats. Look at it and then judge.
Re: Taking it to the next level? Wow! [Re: ECS] #77540
08/12/08 10:15 PM
08/12/08 10:15 PM
mopar346 Offline
mopar346  Offline
double studded end
The link is a rod with a bevel to hold the inside washer and studs on both ends that nuts go on.
E-mail me and I can send you a pic of what I am talking about. I have pulled this style off of many Mopars including my AAR, 69 R/T Charger, 69 GTS, and 68 RR.
Post deleted by moparts [Re: mopar346] #77541
08/12/08 10:18 PM
08/12/08 10:18 PM
