Calling all Holley 660 Center Squirter Tuners
#774471
08/15/10 09:12 PM
08/15/10 09:12 PM
Posts: 553 Kentucky
clovis
Kentucky
After a couple of years with my 1850's, I have decided to give some Holley center squirters a try on my tunnel ram. I rebuilt both to factory specs and have them on the car. On the initial start, it is definitely rich. I am about 2 turns out on the idle mixture, but I am thinking I am going to have to place some restriction (wire) in the idle circuit to get it leaned out enough. The factory main jetting is 76, and I am leaning toward going down a few steps but am curious what others have done with them.
I've got about 6 lbs of pressure on them and it is idling around 1k. This a race only 451-10.89/123 mph.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Calling all Holley 660 Center Squirter Tuners
[Re: Cab_Burge]
#774474
08/15/10 11:07 PM
08/15/10 11:07 PM
Posts: 553 Kentucky
clovis
Kentucky
I'll put the wire in the idle fuel restrictor in the block. I will likely try Grumpy's recommendation and use a .017 wire to start. Like I said before I am also considering leaning out the main jetting from the stock 76 setting. I am hoping that by reducing the mains to maybe 73 and inserting the wire, I can tune from there with the idle mixture. The secondary plate are basically 73, so basically I would have them all square. Quick Fuel makes a modified secondary plate that accepts jets, so I may go that route if necessary before going to a full block in the back because if I go full block I will have turn them sideways and I would rather not have to deal with the linkage unless I have to.
[Re: clovis]
#774477
08/16/10 12:30 AM
08/16/10 12:30 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I ran a pair of them inline. I used only one to idle on. Both had .018" wires in the slots in the blocks. Also ground some of the secondary cam off to retard opening of the secondaries. I didn't have a really good converter. This is old school, but it worked for me 30 years ago. My
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#774478
08/16/10 01:32 AM
08/16/10 01:32 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
They dont respond much to jet changes for some reason, sounds funny but true. The last set I had didnt respond very well to most any changes, like jetting.. So far I believe they run best with the factory settings, jets, restrictors etc. I picked these carbs up for a a few hundred bucks last winter, I took ten apart and blow out the holes, thrown on some used gaskets on them turned the idle mixture screws out abut 1 3/4 - 2 turns. They idle very nice, they will come around even better with some more tuning. and set the timing on the engine.. No stumbles or flat spots. BTW These will be for sale some time later on when I get the car sorted out some.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: clovis]
#774479
08/16/10 08:44 AM
08/16/10 08:44 AM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
I used to run 660's on my last race Hemi, they were a pain to get to run consistant, sent them to Chuck Nuytten to have them "matched" and they became the best carbs I ever ran. never had to futz with them and my ET were very consistant.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#774480
08/16/10 06:27 PM
08/16/10 06:27 PM
Posts: 553 Kentucky
clovis
Kentucky
It is fat at idle, it blackened up the plugs in just a few minutes of run time, so I was a little concerned it might load up pretty badly just driving through the pits and in the staging lanes. I have heard that this has been a problem for others.
If you have to idle up enough to get into the idle transfer slot, the idle mixture is rich enough that the idle mixture screw cannot completely correct it, thus the need to reduce the fuel via the wire in the idle restriction hole.
I have also heard the same that they are not extremely reponsive to jet changes and that there is not a lot of tuning to perform on them. As someone has already said also, they tend to run better in near stock form.
Where did most of you wind up on main jetting? Grumpy's book stated that you should be able to find a home somewhere between 69-75.
