This is givin me a freakin headache, whats the deal? #773946
08/15/10 12:54 AM
08/15/10 12:54 AM
Missouri
StrokerPost Offline OP
Missouri
Was rewiring a guys race car, he had no relays and no circuit protection on the fuel pump, water pump or the fan. So I give everything its own relay and circuit breaker, the only thing I did different than I've always done is instead of switching the small HOT wire, I wired it to switch the ground off the relay cuz thats what an article I read said was the proper way to do it. The only "common" connection here is the power point on the firewall, the main feed from there to the breaker and then to the relays for the the w/p and fan come off that. The main feed to the fuel pump comes off the batt. Ok, the problem I have is I turn on any one of the toggles for those components, THEY ALL COME ON!! Why is that? Again, the ground off the relays, not the hot wire, run through the toggles and then to a chassis ground. Even if I pull the ground off the toggle that goes to the chassis for 2 of the 3 circuits, EVERYTHING comes on. What gives? Is it not possible to have more than one relay on a car wired in this way? Is it in someway "backfeeding"? I'm at a loss. I used the same brand stuff I always use, just wired it a bit diff. I wanted to get some input before I went and ripped out several hours of work to wire it the way I normally do it.
Thanks,
Ken.
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773947
08/15/10 01:09 AM
08/15/10 01:09 AM
Missouri
Missouri
BTW, this is the diagram I'm working from, its wired just this way.
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773948
08/15/10 01:19 AM
08/15/10 01:19 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
My guess is they are all grounding through the mounting brackets.Try leaving them loose and see if they work,if they do,just mount them to a plastic panel.
Re: This is givin me a freakin headache, whats the deal? [Re: Dunnuck Racing] #773949
08/15/10 01:26 AM
08/15/10 01:26 AM
Missouri
Missouri
You mean the toggles? I used lighted toggles that have plastic bodies. The 30A relays are also plastic bodied.
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773950
08/15/10 01:31 AM
08/15/10 01:31 AM
Northern Indiana
Northern Indiana
I was thinking the relays.I have bought some before that had a plastic body,with a small metal mounting bracket.If you mounted them to metal they would ground through the bracket.
I just assumed that is what you were using.
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773951
08/15/10 01:40 AM
08/15/10 01:40 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That is the correct way to wire them and you can have more than one because my highway tractor has about 20 circuits wired like that. The relays run on switched ground. The only difference I see tho is the primary side of the relays on mine get their power from a separate circuit on its own 5a breaker. Don't know if that matters or not. I think whatever it is it will be ground related. When you step on the brakes and the dash lights come on it usually means the brake lights lost their ground and draw back thru the tail lights which will light up the dash.
Kevin
Re: This is givin me a freakin headache, whats the deal? [Re: Twostick] #773952
08/15/10 01:56 AM
08/15/10 01:56 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
is it possible that the relays are wired to a normally closed circuit, which powered they would be then open or "off"?
Other than that just use your volt meter and check continuity between the ground and the relay too check to see if its already grounded?
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773953
08/15/10 03:05 AM
08/15/10 03:05 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
a race car should only have one relay on the fuel pump. with relays too many wires too many things to go wrong. a good switch, correct wire size and a fuse are all you need
home of the
Sox and Martin Hemi Duster
Re: This is givin me a freakin headache, whats the deal? [Re: Bob_Coomer] #773954
08/15/10 03:06 AM
08/15/10 03:06 AM
Missouri
Missouri
DING, DING, DING, DING...... I think we have a winner. Just for grins I went back out and simply reversed the positions of the wires on each toggle and now everything SEEMS to be working normally. I still cannot wrap my head around why, but, for now its working. The only "problem" is that with no power lead going to the switches, the lighted switches...arent. Didnt think about that, so, its either leave it like it is, or rewire it the way I used to do it and have the lighted switches. Oh well, thanks guys for throwing some brain cells at this.
Ken.
Re: This is givin me a freakin headache, whats the deal? [Re: Bob_Coomer] #773955
08/15/10 01:03 PM
08/15/10 01:03 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Can he replace the relays with ones that are normally open "off"? And everything would work correctly? Maybe I don't understand his setup....
Re: This is givin me a freakin headache, whats the deal? [Re: StrokerPost] #773956
08/15/10 08:41 PM
08/15/10 08:41 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
without seeing an exact schematic of what you had i can't say for certain but i would be very suspect it is/was the lighted switches and the way you had it wired causing the problem. if one side of the lamp is grounded and the other side connected to the relay (the terminal you're grounding) the lamp will often pull enough to energize the relay coil and turn it on.
Re: This is givin me a freakin headache, whats the deal? [Re: jamesc] #773957
08/15/10 09:50 PM
08/15/10 09:50 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Without seeing a schematic of the lighted switches can't say for absolute sure. But, I will bet the problem is in the switch panel. Just take the wire off the switch and ground it. This way there is nothing to backfeed. If 12 volts from the light portion of the switch goes to the coil on the relay you meant to ground to activate you now have 12v on each side of the coil. No potential difference, I MEAN VOLTAGE.
Leon
Re: This is givin me a freakin headache, whats the deal? [Re: HEMIFRED] #773958
08/15/10 10:58 PM
08/15/10 10:58 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I agree
