{{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} More Questions #772585
08/12/10 07:39 PM
08/12/10 07:39 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Anyone have one or know who might have one in stock.....I have ck'd a few sources and the MP unit is on national back-order with know delivery date.....
Thanks in advance,
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772586
08/12/10 07:48 PM
08/12/10 07:48 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I think there are a few in the swapmeet area.
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772587
08/12/10 07:49 PM
08/12/10 07:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
There was a couple for sale in the A engine section. I had trouble getting the gasket set for mine.
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772588
08/12/10 11:17 PM
08/12/10 11:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
Don't run one unless you have to
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772589
08/13/10 12:32 AM
08/13/10 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Drill and tap the block to run a remote filter...
makes it much easier and more clearance for the headers
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: MR_P_BODY] #772590
08/13/10 12:45 AM
08/13/10 12:45 AM
scratchnfotraction Offline
PM sent rickster
you can allways drill it to 1/2" and massage the 90* turn and gasket match it
along with all the other oiling mods to the oil pump and rear main cap and drilling the 9/32 oil galleys...well you know..
i got the 9/32 drill bit and the short 1/2 drill bit..just dont have the 10-12 inch bit for the deep one to the oil filter 90*
the last one i did,i spent most of the time in the 90* the fliter plate and removeing the cross section of the factory drill bit end flukes
man the things you can do with an angle grinder and a dremal tool
and about an 18 pack of miller light
I had about 40 hrs in the home gasket match,home pocket port,block stress relieveing
did the main webs and all to the oil gally and return holes opend up
herb and hensleys little blue book,I wish I could find another copy of it
all I gots left is a rag with herbs oil mods on a 360 left
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: justinp61] #772591
08/13/10 08:33 AM
08/13/10 08:33 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I just bought two kits from our local Dodge dealer part# P5249320 oil filter adapter gasket kit. try here http://www.mopartsracing.com/parts/a.html
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: formula S] #772592
08/13/10 10:45 AM
08/13/10 10:45 AM
Been there done that.....anyway I've decided to just pick up the stock plate and fitting for now and may go with either a moroso or canton remote setup down the road....right now I just need to get the moder primed and the lifters pumped up.
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772593
08/13/10 11:24 AM
08/13/10 11:24 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
my warehouse has one in stock #DIRP5249624, $160 plus shipping. your clamps are on their way, bill you after i get back from nats, http://www.tdperformance.com/products/?id=3314 this is what i'm using on my 340, $62 +, dean
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: deansrr] #772594
08/13/10 12:06 PM
08/13/10 12:06 PM
Thanks Dean Not really a fan of the Transact Products....lets just say I had some problems awhile back....I'm sure your setup works fine Thanks again....but I believe I've got it covered
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772595
08/23/10 02:43 PM
08/23/10 02:43 PM
Got to give a quick shout-out and a huge thank you to Chris (DC4126) for sending me out a right angle adapter for just the cost of the ride....Thanks Chris
Do have a question, since I've never used one an anyone tell me what the correct gaskets and placement of them would be for this adaptor...????? (Mopar 2951995)
Will the stock adaptor gaskets work...??? I have a set of those
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772596
08/23/10 02:47 PM
08/23/10 02:47 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Big round gasket ( obvious..lol) against the block and adapter plate, small metal cored gasket under the head of the bolt, cork gasket at end of bolt, but UNDER the plate, so it seals between the plate and the block.
RIP Monte Smith
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: CompWedgeEngines] #772597
08/23/10 02:49 PM
08/23/10 02:49 PM
Thanks I have the cork one and the large one, now to dig up the metal one
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772598
08/23/10 02:53 PM
08/23/10 02:53 PM
Chris.....your in-box is full
Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} [Re: rickstershemi] #772599
08/23/10 02:55 PM
08/23/10 02:55 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
