Page 7 of 8 1 2 3 4 5 6 7 8
Re: Project Belvedere SRT-8 [Re: Crock] #772551
08/24/11 10:59 PM
08/24/11 10:59 PM
Georgia, United States,
Crock Offline OP
Crock  Offline OP
Overview with everything fuel rail and radiator hose
Re: Project Belvedere SRT-8 [Re: Crock] #772552
09/14/11 10:03 PM
09/14/11 10:03 PM
Crock Offline OP
Crock  Offline OP
X pipe to give it a deeper sound.
Re: Project Belvedere SRT-8 [Re: Crock] #772553
09/14/11 10:13 PM
09/14/11 10:13 PM
Crock Offline OP
Crock  Offline OP
fuel filter, fuel line, and fuel regulator
Re: Project Belvedere SRT-8 [Re: Crock] #772554
09/14/11 10:23 PM
09/14/11 10:23 PM
Crock Offline OP
Crock  Offline OP
Everything together and fuel issue after spending over 2000 in parts the I ended up finding out that the relay controlling the fuel pump was not allowing all the power require to make the fuel pump function. So I have straight wired it to the battery.
Re: Project Belvedere SRT-8 [Re: Crock] #772555
01/03/12 11:26 PM
01/03/12 11:26 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Did you ever go back to the dyno? Also what was your fuel system as the "tech article" showed a simple Gm filter solution with built in regulator.
-C
Re: Project Belvedere SRT-8 [Re: ramman5600] #772556
02/09/12 12:30 AM
02/09/12 12:30 AM
Crock Offline OP
Crock  Offline OP
-C
No I never got a chance to go back to the dyno. The fuel system at first was a Mallory external fuel after the gm filter with the stock 5/16 lines. Then change it to -6an lines from the pump to the fuel rails. Then I exchange the fuel rail for aftermarket fuel rails. After that I change to the rock valley fuel pump built into the tank that supports up to 600 hp. Finally the solution to the entire problem was a fuse relay built into the harness that suppose to allow power once the vehicle is started. I put a switch between the fuel pump and a power source and it solved the problem I'm still working with the company to see why it cause the problem
Re: Project Belvedere SRT-8 [Re: Crock] #772557
02/09/12 12:34 AM
02/09/12 12:34 AM
Crock Offline OP
Crock  Offline OP
Finally got it to the paint shop here are some updates
Re: Project Belvedere SRT-8 [Re: Crock] #772558
02/09/12 12:43 AM
02/09/12 12:43 AM
Crock Offline OP
Crock  Offline OP
The other side
Re: Project Belvedere SRT-8 [Re: Crock] #772559
02/09/12 12:44 AM
02/09/12 12:44 AM
Crock Offline OP
Crock  Offline OP
trunk at the body shop
Re: Project Belvedere SRT-8 [Re: Crock] #772560
02/09/12 12:45 AM
02/09/12 12:45 AM
Crock Offline OP
Crock  Offline OP
Front end
Re: Project Belvedere SRT-8 [Re: Crock] #772561
02/09/12 12:46 AM
02/09/12 12:46 AM
Crock Offline OP
Crock  Offline OP
Inner fender at the body shop
Re: Project Belvedere SRT-8 [Re: Crock] #772562
02/09/12 12:48 AM
02/09/12 12:48 AM
Crock Offline OP
Crock  Offline OP
Hood and motor shot
Re: Project Belvedere SRT-8 [Re: Crock] #772563
02/09/12 12:49 AM
02/09/12 12:49 AM
Crock Offline OP
Crock  Offline OP
Last shot of the hood
Re: Project Belvedere SRT-8 [Re: Crock] #772564
02/09/12 09:45 AM
02/09/12 09:45 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Looking good. Bet you cant wait to drive it again. keep the updates coming
Re: Project Belvedere SRT-8 [Re: johnscudashop] #772565
04/14/12 05:18 PM
04/14/12 05:18 PM
Crock Offline OP
Crock  Offline OP
More body shop photos
Re: Project Belvedere SRT-8 [Re: Crock] #772566
05/19/12 01:09 AM
05/19/12 01:09 AM
Crock Offline OP
Crock  Offline OP
body work takes some time
Re: Project Belvedere SRT-8 [Re: Crock] #772567
05/19/12 01:12 AM
05/19/12 01:12 AM
Crock Offline OP
Crock  Offline OP
still in the shop
Re: Project Belvedere SRT-8 [Re: Crock] #772568
05/19/12 01:16 AM
05/19/12 01:16 AM
Crock Offline OP
Crock  Offline OP
almost there
Re: Project Belvedere SRT-8 [Re: Crock] #772569
05/19/12 01:21 AM
05/19/12 01:21 AM
Crock Offline OP
Crock  Offline OP
paint is on now
Re: Project Belvedere SRT-8 [Re: Crock] #772570
05/19/12 01:24 AM
05/19/12 01:24 AM
Crock Offline OP
Crock  Offline OP
side view with paint
