Page 6 of 8 1 2 3 4 5 6 7 8
Re: Project Belvedere SRT-8 [Re: Crock] #772531
07/13/11 11:45 PM
07/13/11 11:45 PM
Georgia, United States,
Crock Offline OP
Crock  Offline OP
Completely disassemble with glove box and running air vents and defrost vents.
Re: Project Belvedere SRT-8 [Re: Crock] #772532
07/13/11 11:50 PM
07/13/11 11:50 PM
Crock Offline OP
Crock  Offline OP
Vent are installed I had to remove my gauges in order to mount the two center vents.
Re: Project Belvedere SRT-8 [Re: Crock] #772533
07/13/11 11:56 PM
07/13/11 11:56 PM
Crock Offline OP
Crock  Offline OP
A pic of all three vents one far left of the steering column, two in the center and one on the passager side. I looking really identical to the original 66 belvedere setups. Only big different is the center vents they were originally mounted in the dash if you have an air condition 66 belvedere
Re: Project Belvedere SRT-8 [Re: Crock] #772534
07/13/11 11:59 PM
07/13/11 11:59 PM
Crock Offline OP
Crock  Offline OP
Wiring has always been crazy for me and with this project it's no different but I will figure it out soon. After market radio, old Ac wires, new wires for the classic auto air perfect fit all together bad combination.
Re: Project Belvedere SRT-8 [Re: Crock] #772535
08/08/11 01:34 PM
08/08/11 01:34 PM
Crock Offline OP
Crock  Offline OP
A quick look at the old unit I had.
Re: Project Belvedere SRT-8 [Re: Crock] #772536
08/08/11 01:37 PM
08/08/11 01:37 PM
Crock Offline OP
Crock  Offline OP
I found that a push rod wasn't connected to the rock arm the results are as follows. Engine went into a limp mode almost little to no power at all
Left side second runner
Re: Project Belvedere SRT-8 [Re: Crock] #772537
08/08/11 10:17 PM
08/08/11 10:17 PM
Crock Offline OP
Crock  Offline OP
My day at the dyno
Re: Project Belvedere SRT-8 [Re: Crock] #772538
08/08/11 10:18 PM
08/08/11 10:18 PM
Crock Offline OP
Crock  Offline OP
Classic Dyno I didn't get the Hp and Tq I wanted
Re: Project Belvedere SRT-8 [Re: Crock] #772539
08/08/11 10:35 PM
08/08/11 10:35 PM
Crock Offline OP
Crock  Offline OP
I finally move that air filter from behind the radiator it really made a lot of improvements.
Re: Project Belvedere SRT-8 [Re: Crock] #772540
08/08/11 10:36 PM
08/08/11 10:36 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
so whats the hp #
Re: Project Belvedere SRT-8 [Re: Crock] #772541
08/08/11 10:39 PM
08/08/11 10:39 PM
Crock Offline OP
Crock  Offline OP
7 inch HID headlights I finally found someone who could get them for me. I really believe they wear made for people who need that extra light at night so see. They shine better then my 09 F-150
Re: Project Belvedere SRT-8 [Re: Crock] #772542
08/08/11 10:40 PM
08/08/11 10:40 PM
Crock Offline OP
Crock  Offline OP
both headlights
Re: Project Belvedere SRT-8 [Re: 10secGTX] #772543
08/08/11 10:55 PM
08/08/11 10:55 PM
Crock Offline OP
Crock  Offline OP
so whats the hp #
unfortunately 365 hp 352 tq but the guy didn't make the pull all the way to the rev limiter. On a stock SRT the limiter is 6200-6400 on my tune he stopped the pull ends between 5500 - 5750 RPM. Everyone keep telling me DO NOT get caught up in a number. Dyno machines purpose is to "Tune" your motor to its fullest, not to provide a number. On a LX vehicle all the aftermarket components I have I should have made in the worst case 415hp 430 tq but as you can see I'm nowhere close to that so I don't know if I'm going to try someone else and see what happen or just leave it the way it is and call it quit.
But to prove what I said here is the Dyno graph.
Re: Project Belvedere SRT-8 [Re: Crock] #772544
08/23/11 10:54 PM
08/23/11 10:54 PM
Crock Offline OP
Crock  Offline OP
http://s1111.photobucket.com/albums/h470/crockettap/
If you have a little time check out some of the pictures I didn't post on here because i figure it would take up to much room.
Re: Project Belvedere SRT-8 [Re: Crock] #772545
08/24/11 10:50 PM
08/24/11 10:50 PM
Crock Offline OP
Crock  Offline OP
My headlight during the day so you can only imagine how much they help at night
Re: Project Belvedere SRT-8 [Re: Crock] #772546
08/24/11 10:51 PM
08/24/11 10:51 PM
Crock Offline OP
Crock  Offline OP
The process of changing the fuel rails i'm still having fuel problems.
Re: Project Belvedere SRT-8 [Re: Crock] #772547
08/24/11 10:52 PM
08/24/11 10:52 PM
Crock Offline OP
Crock  Offline OP
Everything apart
Re: Project Belvedere SRT-8 [Re: Crock] #772548
08/24/11 10:56 PM
08/24/11 10:56 PM
Crock Offline OP
Crock  Offline OP
The new fuel rails this should allow me to connect my fuel regulator on the return line instead of at the tank
Re: Project Belvedere SRT-8 [Re: Crock] #772549
08/24/11 10:57 PM
08/24/11 10:57 PM
Crock Offline OP
Crock  Offline OP
The finished product
Re: Project Belvedere SRT-8 [Re: Crock] #772550
08/24/11 10:58 PM
08/24/11 10:58 PM
Crock Offline OP
Crock  Offline OP
Killerglass radiator hose I like it some may not.
