Page 5 of 8 1 2 3 4 5 6 7 8
Re: Project Belvedere SRT-8 [Re: MuuMuu101] #772511
04/27/11 07:04 PM
04/27/11 07:04 PM
Georgia, United States,
Crock Offline OP
Crock  Offline OP
I remember when you posted that accident. How are the repairs coming along? I don't see the attachment in your new post.
I have majority of the repairs complete here is the most recent pic i have of it
Re: Project Belvedere SRT-8 [Re: Crock] #772512
04/27/11 07:25 PM
04/27/11 07:25 PM
Crock Offline OP
Crock  Offline OP
Normally after having a accident you would rebuild and be happy with that. Well in my case I figure a little more speed wouldn't hurt.
Re: Project Belvedere SRT-8 [Re: Crock] #772513
04/27/11 07:26 PM
04/27/11 07:26 PM
Crock Offline OP
Crock  Offline OP
Ported and polished heads from Inertia.
Re: Project Belvedere SRT-8 [Re: Crock] #772514
04/27/11 07:27 PM
04/27/11 07:27 PM
Crock Offline OP
Crock  Offline OP
Ported and polished intake from Inertia
Re: Project Belvedere SRT-8 [Re: Crock] #772515
04/27/11 07:37 PM
04/27/11 07:37 PM
Crock Offline OP
Crock  Offline OP
I had to replace the value cover some how the passage cover crack along the coil pack during the accident.
Re: Project Belvedere SRT-8 [Re: Crock] #772516
04/27/11 07:44 PM
04/27/11 07:44 PM
Crock Offline OP
Crock  Offline OP
I remove the 5/16 fuels lines that feed the original slant 6 and replaced them with -6AN Aeroquip Performance Hose to help fuel issue i was having the 6.1
Re: Project Belvedere SRT-8 [Re: Crock] #772517
04/27/11 07:46 PM
04/27/11 07:46 PM
Crock Offline OP
Crock  Offline OP
Everything together finally should be around HP465!!!!!!! I will find out soon I have a video but I'm a little unsure on how big a file can be upload for a video
Re: Project Belvedere SRT-8 [Re: Crock] #772518
04/27/11 07:49 PM
04/27/11 07:49 PM
Crock Offline OP
Crock  Offline OP
Night photo of tach and interior lights
Re: Project Belvedere SRT-8 [Re: Crock] #772519
04/27/11 07:58 PM
04/27/11 07:58 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
It's coming together real good! One of the best things about getting in an accident, I guess, is that you can fix, change or add, things you didn't have the time or money to do before. Really liking the new heads and especially the LED lights under the dash. My friend did the same thing to his Eclipse. But then again, he put some under the seat, in the trunk, and in his speakers.
Re: Project Belvedere SRT-8 [Re: MuuMuu101] #772520
04/27/11 09:37 PM
04/27/11 09:37 PM
houston texas
gremlinsteve Offline
houston texas
check those heads and make sure that there are spring locaters on thm, that guy used to run those heads without locaters. just a freindly fyi
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Project Belvedere SRT-8 [Re: Crock] #772521
04/28/11 11:04 PM
04/28/11 11:04 PM
808CUDA Offline
808CUDA  Offline
The best way to find this article is to Google 5.7/6.1 HEMI into your 'ole Mopar. It's going to take you to Moparts tech and that's the article i used to complete my car. It has great pictures and step by step everything you need to do to complete your car. I hope this helps.
Glad to read this article helped you out
I can't believe it has been over 3 1/2 years since I wrote that article
Sorry to read about your mishap
Here's the link to the article:
https://board.moparts.org/ubbthreads/show...e=1#Post3930520
Re: Project Belvedere SRT-8 [Re: 808CUDA] #772522
04/28/11 11:10 PM
04/28/11 11:10 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Awesome Article! I think I may use it to help me with my GEN III in my Dart swap... Well, that is if I ever get the money to do it
Re: Project Belvedere SRT-8 [Re: MuuMuu101] #772523
06/13/11 10:29 PM
06/13/11 10:29 PM
Crock Offline OP
Crock  Offline OP
If you look back a few post you can see where my door panel started to warp from just being in the sun and weather so many years. I finally took the time to remove them and have them fixed.
Re: Project Belvedere SRT-8 [Re: Crock] #772524
06/13/11 10:41 PM
06/13/11 10:41 PM
Crock Offline OP
Crock  Offline OP
Everyone if you would help me make a decision should I keep the panel the way it is in the post before this or should i go with the metal trimming. The only reason my friend didn't install it is because the new panels are wider than the old so I'm trying to decide weather I should keep the panel the way it is or install the metal trimming.
Re: Project Belvedere SRT-8 [Re: Crock] #772525
06/13/11 10:56 PM
06/13/11 10:56 PM
Crock Offline OP
Crock  Offline OP
I needed to monitor the AFR so I put a new gauge in soon as I figure out how to post a video I will post a video of it running still haven't worked all the bugs out but it runs
Re: Project Belvedere SRT-8 [Re: Crock] #772526
06/13/11 11:03 PM
06/13/11 11:03 PM
Crock Offline OP
Crock  Offline OP
Also added a Billet catch can a little insurance to ensure everything run smoothly
Re: Project Belvedere SRT-8 [Re: Crock] #772527
06/13/11 11:11 PM
06/13/11 11:11 PM
Crock Offline OP
Crock  Offline OP
New part shop Hemi 90 mm throttle body with the nitrous injector built in just in case I need that little extra to get the win one day.
Re: Project Belvedere SRT-8 [Re: Crock] #772528
07/13/11 11:37 PM
07/13/11 11:37 PM
Crock Offline OP
Crock  Offline OP
Trying to create a cold air intake for the limited space I have
Re: Project Belvedere SRT-8 [Re: Crock] #772529
07/13/11 11:39 PM
07/13/11 11:39 PM
Crock Offline OP
Crock  Offline OP
Parts all over the places I have finally broke down an trying to install AC. I have went several years without it but now the summer have become to much.
Re: Project Belvedere SRT-8 [Re: Crock] #772530
07/13/11 11:41 PM
07/13/11 11:41 PM
Crock Offline OP
Crock  Offline OP
Finally got it mounted lets see what's next
