Page 4 of 8 1 2 3 4 5 6 7 8
Re: Project Belvedere SRT-8 [Re: nates69b] #772491
10/06/10 11:05 PM
10/06/10 11:05 PM
Georgia, United States,
Crock Offline OP
Crock  Offline OP
not really? I follow the tech article how to install a 5.7/6.1 HEMI into your 'ole Mopar and didn't have any problem everything he warned again was right on the money.
Re: Project Belvedere SRT-8 [Re: Crock] #772492
10/06/10 11:07 PM
10/06/10 11:07 PM
Crock Offline OP
Crock  Offline OP
out with the old in with the new
Re: Project Belvedere SRT-8 [Re: Crock] #772493
10/06/10 11:19 PM
10/06/10 11:19 PM
Crock Offline OP
Crock  Offline OP
the new Competition Engineering Rear Shocks
Re: Project Belvedere SRT-8 [Re: Crock] #772494
10/13/10 07:38 PM
10/13/10 07:38 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
Where you find that article?
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Project Belvedere SRT-8 [Re: Mills] #772495
10/20/10 09:05 PM
10/20/10 09:05 PM
Crock Offline OP
Crock  Offline OP
The best way to find this article is to Google 5.7/6.1 HEMI into your 'ole Mopar. It's going to take you to Moparts tech and that's the article i used to complete my car. It has great pictures and step by step everything you need to do to complete your car. I hope this helps.
Re: Project Belvedere SRT-8 [Re: Crock] #772496
10/20/10 09:21 PM
10/20/10 09:21 PM
Crock Offline OP
Crock  Offline OP
Factory replaced with tubular upper and lower control arms dynamic strut bars
Re: Project Belvedere SRT-8 [Re: Crock] #772497
10/20/10 09:27 PM
10/20/10 09:27 PM
Crock Offline OP
Crock  Offline OP
Upper Arms
Re: Project Belvedere SRT-8 [Re: Crock] #772498
10/20/10 09:31 PM
10/20/10 09:31 PM
Crock Offline OP
Crock  Offline OP
everything entire setup
Re: Project Belvedere SRT-8 [Re: Crock] #772499
10/20/10 10:00 PM
10/20/10 10:00 PM
Crock Offline OP
Crock  Offline OP
Old Arms Rest Pads/Arms Rest Base
Re: Project Belvedere SRT-8 [Re: Crock] #772500
10/20/10 10:01 PM
10/20/10 10:01 PM
Crock Offline OP
Crock  Offline OP
New Arms Rest Pads/Arms Rest Base
Re: Project Belvedere SRT-8 [Re: Crock] #772501
10/20/10 11:52 PM
10/20/10 11:52 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
car looks fantastic! what harness and ecu setup did you go with?
Re: Project Belvedere SRT-8 [Re: dangina] #772502
10/21/10 09:47 PM
10/21/10 09:47 PM
Crock Offline OP
Crock  Offline OP
I used the hotwireauto.com setup they have 5.7 truck pcms with manuel transmission and a custom made harness that's almost impossible to see on the engine if setup correctly. They flash the pcm with the 5.7 Hemi setting and from their you have to contact the company B&G Chrysler speak to Dave and he can flash the pcm with the 6.1 setting
Re: Project Belvedere SRT-8 [Re: SRT6776] #772503
10/24/10 11:57 PM
10/24/10 11:57 PM
Crock Offline OP
Crock  Offline OP
Cool project!
Are you leaving the hub caps on it?
No i don't plan to leave the hub caps on it any ideas on what would look good on a belvedere
Re: Project Belvedere SRT-8 [Re: Crock] #772504
01/26/11 10:24 PM
01/26/11 10:24 PM
Crock Offline OP
Crock  Offline OP
Recent activity and the reason i haven't upload anything in a while Sad day for Project Belvedere
Re: Project Belvedere SRT-8 [Re: Crock] #772505
01/26/11 10:26 PM
01/26/11 10:26 PM
Crock Offline OP
Crock  Offline OP
I really should have put the rear disc brake on.
Re: Project Belvedere SRT-8 [Re: Crock] #772506
01/26/11 10:41 PM
01/26/11 10:41 PM
Crock Offline OP
Crock  Offline OP
Damages: Front Bumper, Passenger fender, Radiator, transmission cooler, Grill, Headlight, air filler,
Re: Project Belvedere SRT-8 [Re: Crock] #772507
01/26/11 10:43 PM
01/26/11 10:43 PM
Crock Offline OP
Crock  Offline OP
inner fender
Re: Project Belvedere SRT-8 [Re: Crock] #772508
01/26/11 10:46 PM
01/26/11 10:46 PM
Crock Offline OP
Crock  Offline OP
The only good news from all this is i found a donor 600 bucks and it suppose to run.
Re: Project Belvedere SRT-8 [Re: Crock] #772509
04/26/11 10:05 PM
04/26/11 10:05 PM
Crock Offline OP
Crock  Offline OP
new updates diablo installed, B&M shifter, and uninstalled column shifter
Re: Project Belvedere SRT-8 [Re: Crock] #772510
04/26/11 10:29 PM
04/26/11 10:29 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I remember when you posted that accident. How are the repairs coming along? I don't see the attachment in your new post.
