Which body filler? #771836
08/11/10 10:57 PM
08/11/10 10:57 PM
FL
74-440Charger Offline OP
FL
Appreciate some opinions on the body filler you use. Picked up a race car thats got a lot of rust comming through faily thick bondo. Going to grind out the bad spots, skuff up the rest and paint. Thanks!
Re: Which body filler? [Re: 74-440Charger] #771837
08/12/10 12:14 AM
08/12/10 12:14 AM
In a van, down by the river
jmf340 Offline
jmf340  Offline
Rage Gold
Got Mopar???
Re: Which body filler? [Re: jmf340] #771838
08/12/10 09:25 AM
08/12/10 09:25 AM
scratchnfotraction Offline
I have been useing the
Dynatron Dyna-deLiight body filler
also use the all metal to fill trim holes and skim coat it with the filler
Re: Which body filler? [Re: 74-440Charger] #771839
08/13/10 02:31 PM
08/13/10 02:31 PM
Jacksonville Florida
elitecustombody Offline
Can never go wrong with Rage Gold from Evercoat or their Extreme filler, it spreads like butter and sands like drywall mud,but it costs around $55 a gallon
Re: Which body filler? [Re: elitecustombody] #771840
08/13/10 02:58 PM
08/13/10 02:58 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
And worth every cent compared to the cost and aggravation of clogged sandpaper using the cheap stuff.
Re: Which body filler? [Re: elitecustombody] #771841
08/13/10 07:43 PM
08/13/10 07:43 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Between the extra time and materials (sandpaper) air compressor running, etc, the rage Extreme is a better deal...
Re: Which body filler? [Re: sthemi] #771842
08/13/10 09:26 PM
08/13/10 09:26 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the paint supply shop near my house has their house brand, it runs down the same line as rages does, but its 15 dollars cheaper a gallon.
metal to metal is great stuff too for a first pass.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
