Re: Clutch over center spring removal
[Re: express]
#771563
08/11/10 04:48 PM
08/11/10 04:48 PM
Posts: 4,285 Ohio
64dodge572
Ohio
With the pedal in the up position you can stack some washers between the coils on both sides of the spring. Push the pedal down and it should take enough tension off that you can remove the spring and keep your fingers! Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: HitIt]
#771565
08/11/10 05:09 PM
08/11/10 05:09 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Removed mine using the washers.I left them in so if I want to reinstall it it will be easy.Rocky
Chrysler Firepower
[Re: Swiss_Robert]
#771570
08/12/10 08:58 AM
08/12/10 08:58 AM
Posts: 403 30 miles west of EuroDisney
fbernard
Is the return spring down at the clutch fork not enough to just lift the throwout bearing off?
Not sure about that, but I can tell you it's not strong enough to bring the pedal back up to its resting position.
