Wiring for interior reverse light 73 Challenger #767846
08/07/10 04:18 PM
08/07/10 04:18 PM
KS
MoparKansas Offline OP
KS
Where does this go to and what type of connector should it have? I am converting my car to a four speed and it never had the light before. The reproduction light I purchased just has bare wires at the end...
Re: Wiring for interior reverse light 73 Challenger [Re: MoparKansas] #767847
08/07/10 04:24 PM
08/07/10 04:24 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
on my 70 cuda it goes from gear box and up thru a hole in the fire wall,through a grommet.theres also a connector on the cable a feet from the fire wall,engine side.check brewers they might have the harness/cables.sorry no pics
Re: Wiring for interior reverse light 73 Challenger [Re: cuda-sweden] #767848
08/08/10 06:42 PM
08/08/10 06:42 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Wiring for interior reverse light 73 Challenger [Re: 64dodge572] #767849
08/09/10 04:53 PM
08/09/10 04:53 PM
KS
KS
Anyone know where the firewall hole should be, by the time I get all the holes drilled due to the 4 speed swap it is gonna look like swiss cheese! So far I have two for the pedal reinforcement and one for the clutch pedal switch wire. Here is the pic of the harness - I assume it hooks to the one wire hanging from the main connector?
