OE Correct Primer process #76656
06/20/08 08:35 PM
06/20/08 08:35 PM
MAIne
MoparABE Offline OP
MoparABE  Offline OP
MAIne
Hi i am getting ready to start the body restoration of my challenger and i am confused as to the original process the body went through at the factory. Could someone please walk me through the correct steps and colors used? I read a very long post on the subject months ago and wound up even more confused. HELP!
Re: OE Correct Primer process [Re: MoparABE] #76657
06/20/08 09:29 PM
06/20/08 09:29 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Was a post the other day on undercarriages for 68 RR. During the thread someone had posted some great pics of the of the chassis and the actual dipping process. Do a search you should find it.
Careful, your character's showing!
Re: OE Correct Primer process [Re: mopar346] #76658
06/20/08 10:00 PM
06/20/08 10:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: OE Correct Primer process [Re: MoparABE] #76659
06/21/08 01:18 AM
06/21/08 01:18 AM
Basically,the bare metal unibody complete with fenders and door,hood and trunklid was dipped in a metal prep acid solution,then rinsed in clear water and dried,then dipped about 1/2 way up in a vat of latex primer[dark grey or black in some cases].This was then washed off the exterior panels.Then a coat of red oxide epoxy primer was sprayed on all the exterior surfaces,followed by a coat of green-grey epoxy that was sprayed over the red oxide and most of the easily viewed inners too.This was then baked,and the exterior was sanded to remove flaws.Then 2 coats of acrylic enamel were sprayed on,and also baked.That is about it.Few parts were painted off the cars by 1970.
