Which k-frame for big block install in a Dart? #766056
08/05/10 02:38 PM
08/05/10 02:38 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I am planning on installing a stroked 383 in my Dart where a slant six currently sits. I have both of the following k-frame set-ups available to do the swap. I have a big block k-frame, mounts and sway bar from a 68 383 Barracuda. I also have a 73 A-body small block k-frame with sway bar and a pair of Schumacher small block to big block mounts for it. I bought the 73 set-up figuring the 68 Barracuda set-up would be worth more to sell and I also like the idea of the spool mount k-frame. However, I have been hearing that the Schumacher mounts set the engine back toward the firewall somewhat from the stock location and sometimes this causes some problems with things like headers fitting properly. Does anyone know if this is true? Which set-up would you use if you were doing this swap?
Re: Which k-frame for big block install in a Dart? [Re: 1970RT] #766057
08/05/10 03:46 PM
08/05/10 03:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can modify the spool K frame just like Chrysler did to create the Direct Connection over the counter piece and use factory big block spool mounts , assuming you can find them .
Me I'd use the Factory Big block K since you have it .
Re: Which k-frame for big block install in a Dart? [Re: JohnRR] #766058
08/05/10 04:12 PM
08/05/10 04:12 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Sell the original big block k-member and mounts, use the sway bar and modify the 73 V8 k-member to Direct Connection specs.
Re: Which k-frame for big block install in a Dart? [Re: Jim_Lusk] #766059
08/05/10 08:51 PM
08/05/10 08:51 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
From what I have heard, the Schumacker mounts are designed to position the motor in the stock location. I have yet to see a case where they did not. I have their replacement mounts in my V8 K frame 360 Frankenduster. Eveerything lines up as it should.
Re: Which k-frame for big block install in a Dart? [Re: Kern Dog] #766060
10/17/10 08:56 AM
10/17/10 08:56 AM
Northern Virginia
barracuda7 Offline
barracuda7  Offline
Northern Virginia
Hi 1970RT,
In case you want to sale the 68 383 Kframe, let me know bro, thanks
Re: Which k-frame for big block install in a Dart? [Re: barracuda7] #766061
10/17/10 11:04 PM
10/17/10 11:04 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, the Schumacher mounts put the engine in the stock location, BUT why in the world would you pay $160 for mounts when you have to modify the k-member anyway?
Yes, on the spool mount k-member you have to shorten the driver side saddle and drill a new 1/2" hole.
Re: Which k-frame for big block install in a Dart? [Re: 1970RT] #766062
10/17/10 11:26 PM
10/17/10 11:26 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
If you decide to make DC Big Block K frame out of you 73 Small Block one. That is all Ma Mopar did. I have a Template we made off a a DC one back in 1982. It clamps right into the 4 K frame to body holes. All you have to do is cut the mount boxes at the center of hole in box. Lay the pieces aside. Cut a little off of boxes, it differs on each side. Bolt the first pieces you cut off to the Template, butt the box pack togeter and weld. Add some plates and Gussits which DC did not do for extra strength. It drops and slides the mounts back. Also you need to cut a small notch where the steering box bolts on for mount clearance and cut the front of the left support angle if you are going to run an HV oil pump. Very simple. I cannot tell you how many we built back in the day instead of paying $350 for the same exact thing from DC. You just use the stock BB spool mounts with this. You are welcome to borrow my template if you want.
Re: Which k-frame for big block install in a Dart? [Re: joewhite440] #766063
10/17/10 11:59 PM
10/17/10 11:59 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Not to hi-jack this post, but wasn't the old DC K-frame built wrong? I ask about big block A-body K-frame and was told that if I got a DC piece that I would have to cut the mounts loose and move them back almost a inch perside. Does that ring a bell???
Re: Which k-frame for big block install in a Dart? [Re: copchaser] #766064
10/18/10 12:18 AM
10/18/10 12:18 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I have read some complaints on them on here. You only slide the top part of the mount back 1/2 inch or so and even less on the passenger side so I do not know where the 1 inch comes from. I know for a fact the ones I always built were even better than the DC ones and never had any complaints or issues. We sold them for 100 using their supplied small block spool type K-members each and did quite a few. I cannot say if the DC ones were bad or not. Just was trying to save the guy some $$$. I am sure some of the BB a-bodies here in Pa and Ohio still have the K members we built in them.
Re: Which k-frame for big block install in a Dart? [Re: joewhite440] #766065
10/18/10 12:57 AM
10/18/10 12:57 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The actual measurements are 1-3/16" on the driver side and 13/16" on the passenger side. The one DC k-member that I used for measurements was slightly different than how I build them now, but considering the quality control of the original pieces that is not surprising.
Re: Which k-frame for big block install in a Dart? [Re: Jim_Lusk] #766066
10/18/10 01:02 AM
10/18/10 01:02 AM
iowa
copchaser Offline
copchaser  Offline
iowa
That's what I was talking about. Thanks guys. That's what this is all about, helping each other out.
Re: Which k-frame for big block install in a Dart? [Re: copchaser] #766067
10/18/10 02:26 AM
10/18/10 02:26 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
After re-reading what I wrote I don't think I was completely clear. The measurements that I posted are from the stock small block location. The actual DC k-member that I used as a measuring tool was at 3/4" and 1", so I had to adjust that by 1/16" and 3/16".
Re: Which k-frame for big block install in a Dart? [Re: Jim_Lusk] #766068
10/18/10 11:43 AM
10/18/10 11:43 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I swapped a 413 into a Dart Sport MANY years ago and just used stock big block spool mounts and a BFH to make clearance for the exhaust manifolds. Don't recall any issues with it other than the used engine was junk.
Kevin
Re: Which k-frame for big block install in a Dart? [Re: Twostick] #766069
10/18/10 04:50 PM
10/18/10 04:50 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
All the Schumacher mounts I have seen used worked good also!
Re: Which k-frame for big block install in a Dart? [Re: 1970RT] #766070
10/18/10 05:08 PM
10/18/10 05:08 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I'd use the 68 383 K frame, too. I ran into a similar problem trying to sell my newly done 451 stroker that I originally built for my 68 Formula S barracuda. We shaved one mount on the side to duplicate the front mount like my orig 383. Now, I can only sell the motor to someone w/ an abody K frame. I don't think Shumacher makes mounts for my scenario, but would recommend you switch K frames & save yourself the expense of conversion mounts, etc.
