big block 400 #765499
08/04/10 08:49 PM
08/04/10 08:49 PM
louisiana
mopar70charger Offline OP
louisiana
i have a rebuilt motor its a mopar big block 400 1972 ..i am trying to get pics of where abouts to the oil sending unit and temperature sending unit , i think its by water neck but not 100%..also anyone knows on the motor if it has 5/8 heater hose nipples or what correct size..before i purchase...please post pics if you have them their always better..thanks and mopar rules while the others drule
Re: big block 400 [Re: mopar70charger] #765500
08/04/10 08:58 PM
08/04/10 08:58 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Both are 1/8" NPT. Oil at the back of the block on top between the intake and bellhousing. Water is on the water pump passenger side.
Re: big block 400 [Re: mopowergtx] #765501
08/04/10 09:03 PM
08/04/10 09:03 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I think a 400 will have one 5/8 hose nipple and a 1/2. But there is usually another spot on the water pump housing with a plug in it which another 5/8 nipple will screw into.
