Swapping a 180 degree T-stat for a 160 degree T-stat #765077
08/04/10 09:29 AM
08/04/10 09:29 AM
St. Clair Shores, Michigan
bigsbigelow Offline OP
Any one pick up any E.T. switching from a 180 degree T-stat to a 160 degree T-stat? I should also ask, what engine temp do you like to see at the starting line?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Swapping a 180 degree T-stat for a 160 degree T-stat [Re: bigsbigelow] #765078
08/04/10 04:16 PM
08/04/10 04:16 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Ryan,I run a 160* thermostat...runs cooler than when I had a 180 in it. I like to pull to the line at about 150*-160* RandyB
