Re: 383man
[Re: Jeff_383]
#764218
08/04/10 12:58 AM
08/04/10 12:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I like the car, here's my Plymouth version.....
I'd say those are great times for your combo. I just took my 452" B motor out for the first time a week ago, and went 12.40. My combo has more cam, bigger headers with 3" dumps, and 3.91's, in a lighter car, You have more cubes, and more carb, Im running OTB Stealths, but you're right where I hope to be! Great build! Nice car! BTW: what are you carrying sandbags in the trunk? My Plymouth weighs in at 3760 with me in it. You've got an RB, but that seems heavy (???).
Re: 383man
[Re: StealthWedge67]
#764219
08/04/10 09:21 AM
08/04/10 09:21 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Cool car, but there's definitely more in it......Personaly, I'd put a better/looser converter in it.......I've got LOTS of customer's cars running around with 3.55 gears and 4,500 to 5,000 stall converters that run in the 10's....... For comparison, this car's went 10.70's @ 124 the first and only time out at 3,500LBS with 3.55's, a STOCK stroke 440, OOTB Edelbrock heads, 850 Demon, big tube headers, and a cam similar to yours....... Another customer's '64 Plymouth weighs 3,870LBS and runs 10.70's @ 124 also with 4.10's and 30" tires.........Another STOCK stroke, pump gas 440 with Indy -1's, mild roller, and 5,500 converter.......
If you can't handle the truth, you're living a lie.......
Re: Good E.T. for my combo?
[Re: LAR_414]
#764223
08/05/10 05:38 PM
08/05/10 05:38 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I think your car runs and looks great! I would do the stuff already mentioned and have fun with it. I personally shoot for a trap RPM that is 300 RPM over your best shift point. My current car shifts at 6600 and traps at 6900. I also prefer ATI converters, I've had the best luck with them in a street/strip car.
Leaving harder in an automatic car just means more RPM.I usually brake torque to 2500 and just floor it on the last yellow.
