Good E.T. for my combo?
#764198
08/03/10 12:05 AM
08/03/10 12:05 AM
Posts: 878 Pittsburgh, Pa
Jeff_383
Pittsburgh, Pa
I went up with Lar_414 last week to the track and just getting some feedback on my times. I've got a #3978 67 B body with 3.55 gears and a 3k stall. Engine is a 499 with OOTB eddys, SD intake, 950HP carb, small solid (247/255, .549/.571). 275/60-15 M&H drag radials. I ran a best of 11.85@114.3 with a 1.70 60ft. I've got SS springs and mopar long shocks. This is with full exhaust (1.75 cheap headers), left in D (shifts at 6k on it's own), and with me driving (I'm not good). Am I in the ball park? I think ther's a little more in it, somewhere
Re: Good E.T. for my combo?
[Re: Jeff_383]
#764205
08/03/10 01:45 PM
08/03/10 01:45 PM
Posts: 7,506 Az
Crizila
Az
ET and speed line up well, as does the 60 foot. Obviously low 11's would be easily attainable with a gear, header change and a little port work. Nice ride!
Fastest 300
[Re: Jeff_383]
#764207
08/03/10 02:08 PM
08/03/10 02:08 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Don't know if this helps, but one of the class racer types says that the optimum ET is 1320/MPH, so going by that, 11.55 would be your optimum ET -almost there
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: Jeff_383]
#764212
08/03/10 07:31 PM
08/03/10 07:31 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm trying. My feet don't always work together. Even when I walk.
hahaha ahhh. 3.91's will help more than ya think. load up the converter some then stomp it as the last yellow pops, shift that thing at 6200 and see how that goes.
383man
[Re: Jeff_383]
#764216
08/03/10 10:45 PM
08/03/10 10:45 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I really like your car alot. 11's from a 2 ton street car with 3.55's that you drive is very good indeed. I think it runs good but I also think it has very low 11's in it with a few changes as stated and some fine tuning. I love the all stock sleeper look. If you really think you are a bad driver maybe try and let someone else make a pass and see how it runs. Good luck with that fine Mopar as I know it will be in the lower 11's soon. Ron
