Re: 340 small block
[Re: cupcake]
#76208
06/19/08 10:26 PM
06/19/08 10:26 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
340s are internally balanced and use neutral flywheels with the exception of the 73 340. it is externally balanced.
I am truckless..
Re: 340 small block
[Re: cupcake]
#76213
06/20/08 08:32 AM
06/20/08 08:32 AM
Any 340 with a forged crank is internally balanced; any 340 with a cast crank is externally balanced. Most, if not all, 73's and some late 72's had cast cranks.
Yours might have a forged crank if it's an early 73, OR if someone swapped in a forged crank some time in the last 35 years.
Check the harmonic balancer. If it has an offset weight on it, your engine is external balanced. If not, it's internal.
Can't help you on where to drill the flywheel to make it external balance.
Re: 340 small block
[Re: MoparforLife]
#76215
06/20/08 09:28 AM
06/20/08 09:28 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Just wondering here. Could you buy one of those B&M offset balanced flex plates and install it between a neutral balance flywheel and crank???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 340 small block
[Re: CJK440]
#76216
06/20/08 11:21 AM
06/20/08 11:21 AM
dogdays
Yes, it's been done. When the first chevy 350 strokers were built using the 400 crank there were additional sheetmetal counterweights that you could bolt between the crank and flywheel. Didn't seem to hurt anything.
The diagram for the flywheel drilling is in the MP chassis book. R.
