stuborn Torsion bar bolts #761928
07/31/10 08:46 AM
07/31/10 08:46 AM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
Ticks and tips to get them bolts on the front end to turn, I need to get the front end up as high as possible to clear the headers on a 72 scamp. I am aware of the implications and alignment issues, but I need the hight right now, and them bolts wont move so I sequster the help of the experts.
Also Hi to any of you that I havnt chatted with in a few yrs, been a while, sucked for a while but im back in a car.
thanks
Re: stuborn Torsion bar bolts [Re: 67Mopar] #761929
07/31/10 09:03 AM
07/31/10 09:03 AM
IN
ahy Offline
ahy  Offline
IN
Sounds like they are frozen pretty well. A good soak with penetrating oil, wait a while and gentle heat may help. You can try backing them out first. If you get them moving, back out all the way. Clean the threads with a wire brush and re-assemble with grease.
Re: stuborn Torsion bar bolts [Re: ahy] #761930
07/31/10 09:23 AM
07/31/10 09:23 AM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
yea soaked with PB just looking for that miracle short cut
Re: stuborn Torsion bar bolts [Re: 67Mopar] #761931
07/31/10 09:42 AM
07/31/10 09:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks
you are going to have to turn it into a 4x4 to get ground clearance , that's the problem with cheap headers , they go under the steering linkage. get a propane torch and heat it up the adjuster nut bar.
Re: stuborn Torsion bar bolts [Re: JohnRR] #761932
07/31/10 09:56 AM
07/31/10 09:56 AM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
John I put the new wheels and tires on the back, the damn nose is about rubbing the asphalt, I had to dig out them old crappy ramps to get it up high enough to get rhe floor jack under the k frame, the back end looks good Its a lot of tire under the back though. Ive never seen these bolts so stuck on anything I ve owned, and its not all rust, I can always budge them
Re: stuborn Torsion bar bolts [Re: 67Mopar] #761933
07/31/10 09:58 AM
07/31/10 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How tall are those back tires ? now you need 15's on the front to even it out Sounds like you need a cheater bar on that wrench handle .
Re: stuborn Torsion bar bolts [Re: JohnRR] #761934
07/31/10 10:09 AM
07/31/10 10:09 AM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
check your phone
Re: stuborn Torsion bar bolts [Re: 67Mopar] #761935
07/31/10 11:55 AM
07/31/10 11:55 AM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
I had the same problem with my Sport Fury. We put the car on a lift, heated the adjuster block, (not the bolt) backed off the adjustment bolt, let cool, then sprayed it with penetrating oil and re-adjusted the ride height. It took about 5 minutes. Be sure to back off the adjustment first.
Re: stuborn Torsion bar bolts [Re: Mopar1] #761936
07/31/10 12:04 PM
07/31/10 12:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure the wheel are hanging.That takes tension off the bars.Then as said spray with good penetrating oil.Work the bols back and forth and some heat on the blocks will help.After they move use anti sieze on them.Rocky
Chrysler Firepower
