999 high clutch drum #760202
07/28/10 03:26 PM
07/28/10 03:26 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
I got my hands on a 5 clutch drum and matching pump. the drum had small groves worn into the area where the stator seal rings are. I to put it in the lathe and turned the area out about .013. just enough to remove the groves but when i put a stock clad ring in the drum it does not fit tight in the bore anymore. the stock bore in the drum is 2.063 now it is 2.078 could i use teflon seal rings or is the drum junk now? thanks Bradley
Re: 999 high clutch drum [Re: roadrunnerreds] #760203
07/28/10 03:41 PM
07/28/10 03:41 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
junk it the seals are made to fit a precise diameter
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 999 high clutch drum [Re: dusturbd340W5] #760204
07/28/10 03:42 PM
07/28/10 03:42 PM
Kissimmee Fl.
Kissimmee Fl.
I have 2 of them if you are interested
Re: 999 high clutch drum [Re: roadrunnerreds] #760205
07/28/10 05:00 PM
07/28/10 05:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Before you create a problem with high gear clutch failure that will be very difficult to diagnois check Dizusters archived thead on this subject. There are many different stack-ups for the 904/999. We burned up high gear clutches for a year before we or anyone else could figure it out. It turned out that the last clutch plate in the stack only sat on the inner lugs of the input shaft by about.020". At higher rpm the disc would jam on the lugs and burn the clutches in the pack. When the rpm came down the clutches would engage. We asked many experts and no one had an answer. Finally we noticed very slight damage to the inner teeth of the last disc only. It was a incorrect match-up of reaction shaft support,input shaft and front drum. Many times the supplied parts for this swap come from a lock-up trans and need a different input shaft. Beware until you know how to identify the correct parts.
Doug
