E-body A/C heaterbox cables? #759470
07/27/10 02:12 PM
07/27/10 02:12 PM
KS
MoparKansas Offline OP
KS
I've looked through all stuff and can't find the cables that go to the A?C controls on my 73 Challenger. Should there be one or two cables? I know there is one that goes to the water valve in the engine bay, is there another? It looks like there are a couple of spots for cables on the controls. Does anyone reproduce these?
Re: E-body A/C heaterbox cables? [Re: MoparKansas] #759471
07/27/10 04:49 PM
07/27/10 04:49 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej.as far as i know,on my 70 cuda with ac there is only one cable,that goes to the watervalve,the rest is controlled by vacuum hoses.
Re: E-body A/C heaterbox cables? [Re: MoparKansas] #759472
07/27/10 05:40 PM
07/27/10 05:40 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
cable from dash control to the water valve is still available from any dealer.
Part #3431459
Re: E-body A/C heaterbox cables? [Re: twodoorpost] #759473
07/27/10 06:08 PM
07/27/10 06:08 PM
KS
KS
Cool - Thanks for the info. Local dealer wants $46.47 for it. Are there any sources that are get it any cheaper? I'll take a picture of the back of the controls and see if anyone can tell me what goes on the other side.
Also what is the source for the vacuum that runs the switches? I haven't seen anything I need to hook up for that.
Re: E-body A/C heaterbox cables? [Re: MoparKansas] #759474
07/28/10 12:17 PM
07/28/10 12:17 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
dont think its cheaper but r.ehrenberg sells them on his ebog site.about the wacuum source,on my -70 383 hp there is a vacuum nipple at the rear of the throttle plate of the holley carb,that vacuum hose then goes through a grommet below the blower motor.after that
Re: E-body A/C heaterbox cables? [Re: cuda-sweden] #759475
07/28/10 02:54 PM
07/28/10 02:54 PM
KS
KS
I found another local dealer that would sell it for $35 and change. There is another guy on Ebay that sells them for $35, so I figured I could get it a little cheaper. Should be here on Tuesday. I still need to get the pic of the back of the control to see if there is something else that needs to be hooked up. Thanks for all the help!
Re: E-body A/C heaterbox cables? [Re: MoparKansas] #759476
07/28/10 06:48 PM
07/28/10 06:48 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Any idea where to get the cable clip that goes on the heater valve? I had an NOS heater valve and when I installed the cable it snapped. It is the metal clip that fastens to the heater valve and you spread apart to rest the cable on.
Re: E-body A/C heaterbox cables? [Re: GKMOPAR] #759477
07/29/10 11:46 AM
07/29/10 11:46 AM
KS
KS
I don't even have my heater valve yet. I have my dash completely out and am trying to get everything under the dash ironed out now. If you have a pic of the clip that would be great. I have a 68 satellite that uses a cable clip to hook to the controls and I wouldn't doubt they use the same type clip on a lot of cars?
Re: E-body A/C heaterbox cables? [Re: MoparKansas] #759478
07/29/10 11:59 AM
07/29/10 11:59 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's an old thread showing some AC parts and pics for the 70-71 E-body....R/T specialties carries the clips.... link Keep in mind a switch was made to a manual, all metal valve somewhere after 71...Not sure on what the deal is on that..
Re: E-body A/C heaterbox cables? [Re: screamindriver] #759479
07/30/10 12:31 PM
07/30/10 12:31 PM
KS
KS
Thanks for the link and those pics. Gives a good idea of the water valve end. I was worried about the dash end at the present time, but will have to work out that end later. I will keep that all in mind. Thanks again!
