Installing new jets in Holley DP. Need help #75673
06/18/08 07:53 PM
06/18/08 07:53 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Need to install new jets in Holley #4150. I believe these are the main jets? (The mains go behind the float bowls correct?) Is this simple enough or are there any special instructions?
Re: Installing new jets in Holley DP. Need help [Re: 68Bullit] #75674
06/18/08 07:58 PM
06/18/08 07:58 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
When you pull the fuel bowl off, you'll see the jets along the bottom of the metering block
Re: Installing new jets in Holley DP. Need help [Re: 68Bullit] #75675
06/18/08 08:27 PM
06/18/08 08:27 PM
Kirkland, Washington
Pacnorthcuda Offline
Funny, I just came up from the garage completing that very task! You either want a little container to snake in under one of the lower bowl bolts OR put a lot of rags under the carb to catch the approx 3 ounces that will spill. Loosen all 4 bowl bolts a little to relieve tension. Remove one of the lower ones and let drain.
Remove the fuel inlet line at the bowl. Remove remaining bolts. Carefully remove the bowl while assiting the removal of the gasket. If your careful and you have the right type (so it does'nt tear) you can reuse. Remove the jets (reg screwdriver, no big deal) install new and reverse process. Torque bowl bolts to 25 inch pounds-not much. Fire car (FIGURATIVELY SPEAKING) check for leaks
Re: Installing new jets in Holley DP. Need help [Re: Pacnorthcuda] #75676
06/19/08 06:27 AM
06/19/08 06:27 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Let me add one more note, when putting the bowl back on, make sure to flip the accel pump arm down (bottom of bowl)so that the spring loaded bolt will land on the top of this arm "before" you bolt the bowl back on.
Re: Installing new jets in Holley DP. Need help [Re: YO7_A66] #75677
06/19/08 10:09 AM
06/19/08 10:09 AM
dogdays Offline
dogdays  Offline
Get a Holley Quick Kit with the blue nonstick gaskets. Then if you tear a gasket you have one handy and the nonstick gaskets are good for a long time. Or buy another reputable manufacturer's nonstick gaskets.
R.
Re: Installing new jets in Holley DP. Need help [Re: dogdays] #75678
06/19/08 07:20 PM
06/19/08 07:20 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
when you pull the bolts out of the bowl, pull One top one first (for venting), then both bottoms. Hold a small can as you pull out the first of the bottom ones. let the gas drain out the bolt holes into your catch can (whatever will fit into that spot, I use a small tupperware). This will help get the job done without spilling gas all over the intake.
