Re: Installing new jets in Holley DP. Need help
[Re: Pacnorthcuda]
#75676
06/19/08 06:27 AM
06/19/08 06:27 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
Let me add one more note, when putting the bowl back on, make sure to flip the accel pump arm down (bottom of bowl)so that the spring loaded bolt will land on the top of this arm "before" you bolt the bowl back on.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: dogdays]
#75678
06/19/08 07:20 PM
06/19/08 07:20 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
when you pull the bolts out of the bowl, pull One top one first (for venting), then both bottoms. Hold a small can as you pull out the first of the bottom ones. let the gas drain out the bolt holes into your catch can (whatever will fit into that spot, I use a small tupperware). This will help get the job done without spilling gas all over the intake.
