Challenger Windshield Install - Tape or Gasket? #75502
06/18/08 03:36 PM
06/18/08 03:36 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
How are the 70 E-body windshields held in ?? Tape or Gasket?? I am getting conflicting info.....
In the shop manual, it looks like its a gasket......
Re: Challenger Windshield Install - Tape or Gasket? [Re: Fabman] #75503
06/18/08 03:51 PM
06/18/08 03:51 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
Factory was butel tape 5/16 thick
performancecarrestorations.com
Re: Challenger Windshield Install - Tape or Gasket? [Re: moparo] #75504
06/18/08 04:04 PM
06/18/08 04:04 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
Challenger windshields do not have a gasket. What they are held in with is the butyl stuff. I don't know if it was a tape. I would think not based on the windshields I have pulled. If it was, it would have to be a very thick butyl w/ a release liner.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Challenger Windshield Install - Tape or Gasket? [Re: Erik] #75505
06/18/08 05:44 PM
06/18/08 05:44 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
Thanks Guys !
Re: Challenger Windshield Install - Tape or Gasket? [Re: moparo] #75506
06/18/08 06:05 PM
06/18/08 06:05 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
3/8" works fine, too.
Re: Challenger Windshield Install - Tape or Gasket? [Re: Fabman] #75507
06/18/08 06:12 PM
06/18/08 06:12 PM
You can purchase the Butyl tape from automotive paint supply shops like RW Mallon or other similar type outlets. The Windshield takes 5/16 tape and the rear glass takes 3/8.
You also need to purchase the pinch weld primer to provide the butyl tape with a proper surface to adhere to.
After carefully setting the windshield I use air to blow (not full force) from inside the windshield and go all the way around the perimeter of the windshield to make certain I have a perfect seal.(of course you need a friend to follow you around the perimeter on the outside to feel for air leaks).
Depending upon the condition of the pinch weld you may have to supplement the butyl tape with urethane windshield sealer to compensate for any leaks that you cannot seal. This will ensure that you are wind noise and leak free. You would apply any supplemental sealer to the area of the pinch weld that is covered by the chrome windshield reveal trim. This way no one will ever know you added any sealer as it will appear as factory.
Re: Challenger Windshield Install - Tape or Gasket? #75508
06/19/08 04:18 PM
06/19/08 04:18 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
Thanks Mike ! Will do......
