5.9 magnum flexplate to 904 in 73 Chall? #754825
07/21/10 11:30 PM
07/21/10 11:30 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
my bud is replacing the knocking original 318 with a truck 5.9 (about a 97) he's recycling all the accy. drives. got the car pan and pickup,crosswind dual pattern intake, etc, down to the final stuff, IIRC he needs a magnum weighted flexplate for the 904....not a factory part? Best /cheapest source?
Thanks, Casey
Re: 5.9 magnum flexplate to 904 in 73 Chall? [Re: Sixgun] #754826
07/22/10 01:42 AM
07/22/10 01:42 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
BTT anyone???
Re: 5.9 magnum flexplate to 904 in 73 Chall? [Re: Sixgun] #754827
07/22/10 05:20 AM
07/22/10 05:20 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Re: 5.9 magnum flexplate to 904 in 73 Chall? [Re: gdonovan] #754828
07/22/10 08:49 PM
07/22/10 08:49 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
use the 94-95 flexplate and add weight to the torque converter
Dan
Re: 5.9 magnum flexplate to 904 in 73 Chall? [Re: Wedgeman] #754829
07/23/10 02:45 PM
07/23/10 02:45 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
would the 97 use any 360 904 non lu convertor?? if so a local trans shop maybe able to weld the weight in the correct position.
what about the b and m flex plates.. will one them work on the mag engine w/904
